We are using a Canon DR-9080C and we keep getting black lines through the documents we scan in and we've cleaned the machine. What can we do to remedy this problem
    Problem Solver:
  • 4 Answers
You want to run (2) tests:
1. Make a copy using a clean, plain sheet of paper from the regular glass top. If it copies clean then:
2. Make a copy from the feed unit. If that is where the streaks are then you just need to clean the scanner glass (this is the small thin glass next the flat, copy glass. Use glass cleaner and a COTTON wipe. You may have to clean it a couple of times to get the residue off the glass. Each time you clean, make a copy.
Posted on Jun 02, 2008
When I scan a document in the canon 9080c scanner - the document when printed will print with a black line through the middle of the page or on the left side of the document. I have changed the rollers and...
Try scanning a few documents in full size mode (scannerrs maximum), If you observe a line in the same location in all images, you can conclude that there is either a scratch in the glass (due to stapler pins) or dirt stuck firmly. Try cleaning with Isopropyl alcohol. For absolute emergency, you can wet a cotton bud in after shave and clean the right spot, take care not to touch any other part other than the glass. If glass is scratched, you need to replace it.
S. Mohan, Chennai, India
Sep 14, 2011 | Canon DR-9080C Path-Through Scanner
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
When I'm scanning a document on Canon 7580 each page will show up on my computer screen with a slighly different margin (keeps shifting left to right). The document is being fed into the scanner...
Under CapturePerfect3, you can choose to deskew the scanned image while scanning itself. Also select 'Image only" radio button instead of 'Guide Plate'. The software will remove black borders around the image.
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Jul 14, 2009 | Canon DR-9080C Path-Through Scanner
HELP BIG JOB DUE TOMORROW! I have a DR 9080c and it just started putting two lines on the scanned pages. I have cleaned the rollers, the glass, run cleaning pages through even used compressed air to blow...
Vertical lines are from dust on the Glass. Use Isopropyl alcohol, no solvents pls. Try scanning in diff contrast levels and if the thichness varies, it is confirmed dust on glass, whereas any fault in the reading unit will be constant and also have sharp edges.
Jul 01, 2009 | Canon DR-9080C Path-Through Scanner
The documents are scanned but dont appear on later inspection, or if they do they are just a horizontal line across the middle
Try reinstalling the driver software. If the problem still persists, run scandisk or reinstall OS.
S. Mohan
Aug 21, 2008 | Canon DR-9080C Path-Through Scanner
107 people viewed this question
jasbo
jasbo
