Question about Sport & Outdoor - Others
Want to change oil in 1990 polaris indy snowmachine can not find oil drain plug
    Genius:
  • 1,478 Answers
Open the front hood of the Polaris snowmachine. Lift up and remove the plastic side panel on the left side of the engine compartment. Put an oil drain pan on the floor. Disconnect the oil return hose, a rubber tube connected to the plastic oil tank. Place the end of the hose into the drain pan to allow the old oil to drain out. It may take up to 30 minutes for all of the oil to drain.
Take care.
Posted on Oct 09, 2010
Do I drain both resevoir and engine on Polaris Sportsman 335 when changing oil?
when changing oil usually you change the oil filter and there is a drain plug for the oil to out...i don't know bout the reservoir your talking about,,
Sep 13, 2015 | Polaris ATV
Oil Change
Depending on the manufacture some come with oil filters and some without. There exists on all machines a drain plug located on or near the bottom of the crankcase housing. Use a suitable container to catch the drain oil ( 1 gallon drain pan ) . Drain the oil completely from the crankcase some drain plugs contain a magnet to catch particles clean it off prior to reinstalling it, reinstall the drain plug. Locate and remove the oil filter making sure the old oil filter base gasket comes off with the old filter, install a new oil filter as described by the manufacture. Then refill the crankcase with the proper mount of new engine oil through the filler plug/ dipstick hole.
Nov 28, 2011 | Polaris ATV
2003 Polaris 600 Twin -- Where is the oil plug located? Trying to change the oil and cannot find it!
On the Polaris twin motors the drain plug is located on the bottom of engine. There is a hole in the skid plate for access to plug. The plug will take a 6mm hex wrench or socket. On the plug there is also a sealing washer, make sure the washer stays on the plug or put it back on if it drops in the oil. Any questions let me know, good luck, Daniel.
Aug 03, 2011 | Polaris ATV
I reringed a polaris indy sport with a indy 500 engine in it, now the gas will shoot out of the spark plug holes. Is the fuel pump diaphram bad? Or are BOTH needels stuck? Or?????
SOUNDS LIKE THE ENGINE IS BADLY FLOODED, SHUT YOUR GASS OFF AND REMOVE THE PLUGS, THAN PULL IT OVER UNTIL IT IS UNFLOODED. IT SOUNDS LIKE THE NEEDLES ARE STUCK IN YOUR CARBS
Dec 10, 2010 | Polaris New Genuine Polaris Snowmobile...
Horsepower output from a 95 polaris xlt 600 snowmachine
A 1995 Polaris XLT 600 snowmobile has a class-leading 120 hp.
Dec 23, 2009 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Oil change for polaris 325
Drain plug is on the bottom of the crankcase. No need to pull skid plate. Combo fill hole and dipstick is on the lower left hand side of the engine
Don't forget to do the filter at hte same time.
Aug 16, 2009 | Polaris ATV
Sport & Outdoor - Others Logo
46 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
