Question about Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition
I have a problem where the heater ignites easily, stays lit for 30 seconds, then turns off, then kicks back up in 30 seconds. Burners look great? Not sure what could be wrong?
  • 990 Answers
If you have a pilot their will be a flame sensor that's part of it. If this is a glow plug start it will be a probe that goes through the fire wall and is just above the burners. When you get flame the electrons align so that you will get a signal back at the ignition control that will let teg heater run. If it dosn't get a signal it shuts down so you don't get a build up of gas. Then it reset's and tries again. What your describing is a bad sensor or wire. Could be carbon build up on the sensor. If you can't find any problems with these you may have a bad ignition control box. First I would check the wire, connectors and probe itself.
Posted on Oct 09, 2010
  • j_jerotz Oct 09, 2010
    When it does fire up, the burners fire and glow great all the way across so i think the signal runs through to fire it, then runs, then shuts down? What sensor or wire are you talking about that could be bad? Thank you
  • Kieran Ruppert Oct 09, 2010
    It will fire and run but it shuts down because it dosen't rcognise the flame. The sensor is the flame sensor I described before depending on what sort of ignition system you have (standing pilot or glow plug) The wire is the one that runs from it to the ignition control. If it dosn't read a signal it shuts the gas down. So yes it will fire as you described in the orignal problem but if it dosn't fire it will shut the gas off. Even if it has fire it won't nesserly read the fire and shuts down anyway, this falls under the heading of the problem. So at the risk of repeating myself. The sensor will be found on the pilot assembly or in the firewall just above the burners about in the center of the wall.
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Thermostat calls for heat, purge motor turns on, 15 seconds later hot igniter turns on, then gas turns on and burners are lit. Problem is, they only stay lit for 5 seconds then shut off and cycle repeats...
,Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 02, 2011 | Goodman Heating & Cooling
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
I am having a problem with a dayton(3E229D) gas heater. It has a standalone pilot that is lit and stays lit. The problem is that the burners don't ignite. I turn the heat on at the thermostat the fan comes...
if you can use a meter check for 24 volts at the valve when you call for heat. If you have 24 volts and no burners then the valve is bad, if you do not have 24 volts then another safety is locking out the valve
Dec 11, 2009 | Dayton Gas Furnace Heater
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
Heater will not stay lit
Leave automatic button depressed for 30 seconds after flame ignites.
Jan 14, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition Logo
176 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
