Question about Frigidaire Washing Machines
Washer will not discarge water - Frigidaire Washing Machines
  • sarks Oct 10, 2010
    thanks i did remove the water and cleaned everything out. It looks like the spin cycle is not working? any ideas for that problem?
  • Frigidaire Master
  • 8,220 Answers
Inside the tub to pump hose is a lint catching basket. Remove the bottom panel and get the hose off. Water will go every where so be ready. Dump out the lint, put everything back and retry.
Posted on Oct 09, 2010
  • 1 more comment
  • Dan Webster
    Dan Webster Oct 10, 2010
    The next thing to check is the control. Does the tub turn freely?
  • sarks Oct 11, 2010
    Yes it moves easily without any noises. it is smooth, unit is 8 years old.
  • Dan Webster
    Dan Webster Oct 11, 2010
    You are down to the motor or the control. Are any codes being displayed?
How do I get my Flash to work?
First turn it on a indicator light will come on when energized
Make sure the correct batterys are installed light will come on faster then discarge I its broke from dropping it the flash wont work
Oct 04, 2014 | Nikon Cameras
My tablet is not charging i dont know why is not opening i use my tablet about a minite awayl ago i really shok beauce my tablet is hang
if its hanged try to discarge it fully and then charge it and retart
if there is charging problem first check your charging cable/charger
if they are allright,,,go to ervice centre there is problem with your charging ic
Mar 05, 2014 | Polaroid Tablets & eReaders
Do I need to discharge the capacitor ij my washer before testing or replacing it? If so, can you provide better details on how to do so please?
You should not need to discarge the capacitor before testing or replacing, but if you need to, simply short across the terminals with a screw driver or similar, taking care not to touch the metal blade of the screwdriver.
Jan 08, 2011 | Washing Machines
8 year old side by side, refrigerator and freezer not cold, compressor running, condenser fan running, discarge line not hot suction line not cold
discharge line not hot suction line not cold. This indicates the compressor is not working properly. It could be out of freon or just not pumping.
Nov 03, 2010 | Maytag Refrigerators
I purchased a new DeWalt DW1916 Battery charger and when I install the battery for charging, the red light on the charger blinks on and off and after an hour the battery was still discarged.
If you look on the charger there should be a flashing codes should be explained depending on the type of flashes. Very fast flashes, means bad battery.
Oct 01, 2010 | Garden
Dishawasher drains but right after lets all the
The check valve might be stuck. The valve is supposed to let the water out but stop it from flowing back in. Also make sure you discharge line has a loop. And check your air gap at the sink(if you have one) and make sure it is not plugged.
Aug 04, 2009 | GE HDA3500NWW Dishwasher
I have a DELONGHI DE400P 40 Pint Dehumidifer.its red led starting send signal(like 3 beep every 10 seconds). I think it can not discarge water secondely, Its draing soket broken during my survy. how I can...
I know, the drain socket just jumped off into your hand....Ther three beeps....a code,,, look inside the panel or paper-work for the code,, &for the leak, "gorilla glue"! Thank-you-very-much!
Aug 27, 2008 | DeLonghi Heating & Cooling
Battery discarged
It might be checking for emails, or trying to sync - check these two options. Or it could be reminders not going away.
Sep 07, 2005 | HP iPAQ HX2110 Pocket PC
Washing Machines Logo
302 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
