Question about Brother GX-6750 Typewriter
Changed Ribbon Changed typewriter ribbon and still wont type?
  • bettemccormi Dec 19, 2008
    I changed the ribbon, and the typewriter won't type. I've tried hitting Code and Reset - didn't help.
Try putting the ribbon in and then turning the typwritter off and back on again. The ribbon should drop down into place.
Posted on Oct 27, 2008
I bought the ribbon and it did not work so I took it back got another
one and it still will not type
Please help
Posted on Sep 23, 2008
  • 132 Answers
Have you pressed the
'spider web' key (asterix in a circle) and + //
Posted on Aug 19, 2008
3 Suggested Answers
  • 329 Answers
SOURCE: Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
Posted on Jun 12, 2008
  • 313 Answers
SOURCE: Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Posted on Jun 12, 2009
Hi, I have an IBM Wheelwriter 30 Series II. When I type text it does not type the bottom 20 % of letters. I changed the ribbon and made sure that the roller was securely locked down. Any suggestions? ...
yes in the carrier ribbon there is a adjustment of ribbon to fix it up and down.
take out the ribbon.
see the cam from where the ribbon carrige lift up.
in side that cam a adjustable screw from that screw you can adjust the ribbon hight.
Nov 25, 2010 | IBM Wheelwriter 30 Typewriter
My typewriter all of a sudden just stopped typing letters. im not sure if the ink has run wasn't fading or anything before it stopped working mid typing
The ribbon might have fade out, please try and replace the ribbon or check the ribbon selector if is not for stencil cutting. If is in stencil cutting it wont print on the papers as u type. Thanks
Apr 29, 2010 | Brother ML-300 Typewriter
Typing half letters
If it was working befor you changed the ribbon check to be sure the ribbon's feet are engaged in the slots on the ribbon deck, that the blue latch is latched and there isn't a fold in the ribbon. If all of these are OK push down firmly on both ends of the platen.
Feb 16, 2010 | Lexmark Wheelwriter 15 Series II...
Just types blank! changed ribbon, sounds the
The plastic print solenoid cap is probably broken. We sell them for 20.00 including instructions and shipping.
Cleveland Business Machines
Nov 30, 2009 | IBM Wheelwriter 30 Typewriter
Selectric II- changed the ribbon, new ribbon won't advance
The ribbon is probably not threaded to the lift of the white slacker finger just left of where it comes out of the cassette.
Sep 30, 2009 | Lexmark Wheelwriter 15 Series II...
Type is faded and old looking even with new ribbon.
Put in a multi part form, if the carbons print well then try a fresh ribbon,. not one that has been sitting around for a long time. If it is bad check for debris around the print hammer, If its clean either the print solenoid is gummy or the solenoid cap is broken.
Jan 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
My typewriter is not making impression
Wheelriters have ribbon drive motors that go bad, take ribbon off and watch as you type is the ribbon drive gear is going around, if not chance you have a bad motor....
Jul 21, 2008 | IBM Wheelwriter 30 Typewriter
May 22, 2008 | Brother Office Equipment & Supplies
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
Brother AX-450 Electronic typewriter
2 thing come to mind you may check.
First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty.
2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon.
Lastly the ribbon drive may be broken or out of adjustment. a minor repair.
Hope this helps...
Jan 08, 2008 | Brother EM-430 Typewriter
Brother GX-6750 Typewriter Logo
310 people viewed this question
James Cagle
James Cagle
Jim Keysor
