Question about Creative Labs ZEN V Plus MP3 Player
Keeping it's place
Why doesn't my Zen keep it's place once it's been turned off and restart where it left off? Thanks
I was having the same problem.
Go to SYSTEM/PLAYER SETTINGS/IDLE SLEEP.
The default setting is 5 min, change to OFF and it seems to work.
When playing a track, press PAUSE and either leave it alone or, LOCK the player and when you UNLOCK the player it should continue were you left off.
Hope it works.
Posted on May 31, 2008
My samsung z400 just keeps restarting and will not turn. i tried pulling the battery and then puttin the battery back in it and then restarting but it keeps restarting over and over what do i do?
There is a high probability that your phone has become wet and moisture has seeped into the inside of the shell. This can happen from splashing liquids on the phone or even from very humid climates. Fill a cup with white rice. Remove your phones battery and place it in the cup overnight. The rice will leech the moisture out of the phone. If it still doesn't work, you may need to see a dealer or contact Samsung.
May 02, 2011 | Samsung Z400 Cell Phone
Nomad jukebox Zen Xtra 30 Gb
does the unit experience power surge when you charge it for the last time..?
Thanks
Apr 28, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
My creative zen is docked to my computer, but the computer says "no player ... My creative zen is not docked but has DOCKED on the screen and won't turn off ...
Unplug your player.
Look on the left side of it, you should see a small hole, use something thin, paperclips work well, to poke inside it, the restart button is in that hole.
Once it's started up reconnect your player, all should work fine now!
Dec 09, 2009 | Creative Labs Zen V MP3 Player
Garmin nuvi 205, sometimes it won't respond to my touch. Sometimes when I go to give it a name or address it just keeps repeating a letter, "aaaa, or jjjj. then when I touch the botton to go back or clear...
Your touch display is shorting out....BAD
Replace Unit
BUT try this first:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Does this help? Let me know. Thank you...
Nov 03, 2009 | Garmin nuvi 205 GPS Receiver
My M45/S331 doesn't start nomally
its happen because you left it and it was overheat pls take care your laptop work or keep in cool place while working.
Jun 10, 2009 | Toshiba Satellite M45-S331 Notebook
Getting out of recovery mode
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already installed...do you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Jul 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
ZEN V PLUS Software Installation
I happen to overlook the warning to install first the software before connecting my new ZEN V Plus to my laptop. Now, whenever I connect my ZEN V Plus to my laptop, it cannot detect the device. Could someone help me what to do? Thanks a lot.
I installed the software for the Zen...
Jun 24, 2008 | Creative Labs Zen V MP3 Player
Creative Zen 16gb
See the Solutions for my Zen "Won't Turn On." Hope you find your answer here. http://www.fixya.com/support/t586491-turn
Damma32
May 30, 2008 | Creative Labs Zen Digital Media Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
