Question about Dell 1600n All-In-One Laser Printer
Toner Doesn't adhere to page. Started out with vertical lines.
Printer started leaving vertical lines when printing or copying. Then it started leaving toner. Finally, the whole page is full of lines and spots.
I replaced the toner cartrige. Didn't help.
When I scan it is fine. The toner collects on the green roller.
Any suggestions. Thanks
  • Charlie Ferrara Sr
    Charlie Ferrara Sr May 30, 2008
    Test page is has unbonded print. Very dirty, toner.
    However, Scanner scans properly to pdf with NO imperfections.
    Where is the fuser? Is there a service manual available?
  • 691 Answers
Sounds like the fuser unit is either not pressing hard enough onto the page or notgetting hot enough to adhere the toner to the page.
Feel if the fuser is hot or has something stuck in it like a sheet of paper wrapped round the roller. If it is not hot then it needs replaced.
Posted on May 30, 2008
    Genius:
  • 3,587 Answers
Can you do a test page. how's that look?
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels May 30, 2008
    yes..I can get you a service manual..need the model and part number from the back of the unit
  • Patrick Michaels
    try this link..if you can't see it, then I'll be able to upload to you, the zip file.
    thankya for using fixya
  • Patrick Michaels
    if you want that zip file, do an Ask me and leave a contact email there.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Hp cm2320nf prints 2 black lines vertical all the way down pg 1/2' apart
Remove cartridge observe on cartridge drum finds any vertical toner line? replace cartridge, as well as check all cartridges same manner...if found replace them..If its only on copying: clean flat bed both glasses..with glass cleaner..
Feb 02, 2012 | HP Laserjet CM2320nf All-In-One Color...
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
Prints a line in a page
if that line is horizontal and repeat itself on the page then the problem should be from the Drum of Toner.(should be fixed if you replace Toner)
if it is vertical line all over the page then it ia allmost the fuser film (torn vertically) and if so you should send the printer to a specialized technician
Nov 26, 2009 | HP Office Equipment & Supplies
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Mar 20, 2009 | HP LaserJet IIIp Printer
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
May 10, 2007 | Brother MFC-7820N Laser Printer
Dell 1600n All-In-One Laser Printer Logo
129 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
