Question about Garden
Hi I have a fish mate pressurised filter 10000UV and a seperate pump. For quite a few months now the water pressure through the decorative taps has varied, some days good, other days it has stopped. I cleaned the filter today and when I put it all back together again and switched it back on, it kept tripping the fuse box in the house. I also noticed the bulb (presumably the UV filter) is black at the bottom. The pump seems to work but as soon as I put the filter back together, it cuts out and trips the fuse. Any ideas what might be wrong?
SOURCE: Hotpoint CTD00 trips the power
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
Posted on Dec 05, 2007
bigg t
  • 640 Answers
SOURCE: Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Posted on Apr 11, 2009
zeusfaber
  • 247 Answers
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
  • 37 Answers
SOURCE: 1999 Jeep Grand Cherokee AC high pressure switch tripping.
did you add freon to your system if so how much try letting some out.
Posted on Aug 29, 2009
  • 23 Answers
SOURCE: MM600 - New Switch - Trips Breaker
Wiring Instructions recommended here:
https://www.fixya.com/secure/support/t2575192-in_replacing_push_button_switch
http://www.fixya.com/support/t383610-wiring_diagram_black_decker_electric
http://www.fixya.com/support/t2997089-black_decker_19in_electric_mower
Posted on Sep 27, 2009
Does the expiration date on the food really matter?
Fish foods often don't have an expiration date on them, but they have a short shelf life. Flake foods lose much of their nutritional value in about a month, so you should purchase only what you can use in a few weeks. Vitamin and nutritional deficiency is a big contributor in making fish susceptible to disease.
Jul 30, 2012 | Fish
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
WHY DOES THE FISHMATE FILTER HAVE 2 POWER LEADS
One lead is for the pump/filter the other is for the UV sterilizer.
Mar 22, 2011 | Fish Mate Pressurized Filter with UVC and...
Can i use this pump in my salt water fish tank
Glad to HELP YOU!
I am an aquarist for MANY YEARS. I do have few tanks at home, one with fresh water and other three with saltwater (reef and fish only).
I'd suggest you DO NOT USE such pump into your saltwater tank.
Stick instead with the classic ones: CORALIFE, MARINELAND, ATLAS and so on.
This Flotec 1/6 Hp 1260 is used mostly for PONDS and DECORATIVE FOUNTAINS. In saltwater some of its plastic parts will release TOXIC SUBSTANCES that will KILL your livestock!!!
My best wishes!
Mar 22, 2011 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Where can I find the transformer for the fish mate 2000 pressurized uv 9w auto clean?
I have a Fish Mate 2000, water got in to the top where the light bulb & electronics are, replace the light bulb, but the Transformer is all rusted looking, can the electronics be replaced? thank Jean
gkracky@bellsouth.net
Aug 28, 2010 | Fish Mate Pond Filter Compact
Motor running, water supply adequate but when
clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Jul 31, 2010 | Karcher 1750 Psi Elec Pressure Washer
Water pressure has dropped off with pressurised water system
hi Peter if you have a mixer tap there are no washers there is a ceramic cartridge in the centre but that should't be the fault
the most common rectification is to undo the airrator which is the filter that the water comes out of and clean any forein matter from it
May 10, 2010 | Grohe Chiara Neu Lavatory Centerset ...
The pressure drops very slowly over a month then needs topping uo from the filling loop to 1.5 bar. when the heating is on it goes upto 3 bar. the pipe outside is slightly damp. it was fine during the...
Sounds like the expansion vessel in the boiler has lost pressure or is faulty. If you have a tyre pressure gauge, locate the expansion vessl and check the pressure via the schraeder valve. It should be around 1.5 bar. If there is no pressure you can re pressurise it with a bicycle pump. Should it not pressurise then you will need a new one. The pressure relief pipework outside is damp because the system is over pressurising at relieving pressure at 3 bar. This obviously causes a system pressure drop. You can install a pressure vesel into the heating return pipework should accessing the boiler be difficult.
Oct 31, 2009 | Water Heaters
2003 50 HP Johnson Water Pump problem at high speed
you need to find out if they just replaced the water pump impellar or the whole impellar housing make sure bolts are tight at mating surface what may have happened is the impellar tube may have not been lined up correctly during installation does the motor get hot let me know so i can figure it out theres only so many things it could be but if it stops pumping youll be in trouble comment me back
Jun 21, 2009 | Boating
I just installed my annual replacement kit for my Fish Mate 3000
Coarse to fine , bottom to top.
manufacturers website
http://www.pet-mate.com/Fish_Mate/Filters/UVBio_PressurisedPond_Filters_US.htm
Mar 29, 2009 | Fish Mate Pond Filter Compact
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
