Question about Samsung L210 Digital Camera
Lens is out camera wont turn on was taking pictures and camera just froze
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Samsung service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 09, 2010
My samsung tl240 lens is stuck wont retract cant take pictures cant zoom. Was neverdropped just froze an stopped working
<div><br /></div> <div>remove the battery and memory card. blow out any dust. put back the battery in and turn it on without the memory card. see if you can take pictures, if so then its your memory card. Check the link below. </div> <div><br /></div> <div>http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&amp;PG_ID=0&amp;AT_ID=264556&amp;PROD_SUB_ID=0&amp;PROD_ID=1008&amp;EMAIL_ID=</div>
Jun 21, 2010 | Samsung TL240 Digital Camera
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I737 digital lens will not move
There is nothing you can do. A tech will need to diagnose and repair it. Sell it at an online auction house to recover some money.
Jan 09, 2009 | Cameras
LCD frozen
These cameras are very heat sensitive, keep them cool. If your camera is still in warranty, Canon may replace it. Good luck, I really like my 410, it's easy on batteries.
May 17, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Blurry pictures, and zoom not working
yeah the same thing happened to my camera last month and I just went to the repair place yesterday. Apprently Casio products arent that sturdy so if they get hit the lens can become misalligned and you can't fix it yourself. A new lens is more than the camera itself so if you have to get a new camera I wouldnt suggest another casio one. Good luck.
Aug 13, 2007 | Casio Exilim EX-S600 Digital Camera
Nikon Coolpix 8700 Lens Error
Take batteries out. leave overnight. make sure batteries are fresh or charged. Put 'em in did it work? No then Nikon Tech help in the first instance also take a look here http://www.fixya.com/support/p422-nikon_coolpix_8800_digital_camera/solutions
May 12, 2007 | Nikon Coolpix 8800 Digital Camera
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Samsung L210 Digital Camera Logo
141 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
