Question about EZ Dupe (EZD-1TCDSO) CD-RW Burner
I keep getting a waning about length but I am coping from a lp to a lp
  • 20 Answers
The CD may be an "overburned" CD, which is longer than your typical CD's length, which would display the the Overflow warning message.
We can solve this problem by holding down the ESC button for 2 seconds, and then accessing the Advanced Setup menu. Under the Advanced Setup Menu, there is a function called "Overburn", which will enable the copying of overburned CDs.
If you still have problems, questions or concerns, please feel free to contact us @ 877-686-8868 x208 for technical support. Thank you and have a nice day.
EZ Dupe Technical Support
Posted on Oct 11, 2010
Can't get temperature over 300 degrees. What could cause this?
If you are using a residential LP cylinder then the check valve needs to be reset. If not, check and adjust the carburetor shutters at the tip of the venturi tube and the set-screw inside the valve stem.
This will correct the issue almost always.
Sep 26, 2014 | Grilling
I'm using my LP-2844 in conjunction with Label Matrix software and I've run into a snag with my printer. When switching between jobs, I went from one label size to another (something i've done...
The problem with this type of printer is that you need to callibrate the size of the label in fact the Length. If you change the length then the printer may stop printing correctly ans stalls.
From your driver try to do a calibration of sensors with your labels and this sould work with this model.
Other manufacturers handle the varying length dynamically.
Jul 13, 2011 | Zebra LP 2844 Thermal Printer
Have a goodman lp gas furnace modelgmpn060-3 furnance starts up get main flame for about 5 seconds then shutsoff
i would start by checking the flame sensor ...if the unit is actually firing off just not staying lit sounds like a faulty or dirty flame sensor.... if you look inside at burner assembly there will be a metal rod ranging from 1 1/2 to 4 inches in length.... it ia in burner assembly and has (1) wire that connects to it and usually one 1/4 inch screw on it.... remove this and lightly /let me emphasize lightly sand it and clean it ...to much will actually damage it...re-install and see if it helps... this senses the flame and tells the control board to keep gas valve open most likely your culprit....good luck to you...
Feb 13, 2011 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Zebra LP 2824 not printing a barcode
check the driver if the length and the with are correct, print a test page, check if come the windows logo and the test from all label. check if the barcode is biguer that the label, if it is, is not appear.
2 solution is to reset printer to factory defult (press button until flash 4 times and relese the button.
Aug 19, 2010 | Zebra Eltron LP 2824 Thermal Printer
With WorkForce 500, I am using only black for coping. But other color inks become low and the coping is stopped. Are there any way to do only the black coping?
replace all color cartridges with black toner
if ink fill your color cartridge with black ink using a refill kit
and just buy a new color cart and keep it asside in a zip lock untill you need color
Aug 03, 2009 | Office Equipment & Supplies
To recover LG RD 3000 mobile unlock code
I WANE UNLOCK CODE FOR LG RD 3000
May 04, 2009 | LG Cell Phones
Changing my record mode from SP to LP
In order to change the menu settings you must 1.)turn on the power 2.) Touch FN to display PAGE 1. 3.) Touch MENU to display menu. Use the arrow buttons to scroll until the TAPE SET menu is highlighted. Press the exec button to reveal SP in RECORD MODE. Press it again to bring up a menu that will give you the choice of SP or LP. When you're done press the exec. button a couple of times and you're done. Do Keep that even though the tape will run 1.5 its normal length there are certain features that cannot be used while in Long Play (LP) mode. I have a sony camera but was looking at your model camera yesterday. I noticed that many of the menus and navigations were the same. I'm assuming that my directions will at least allow you to know what menu to look for. Good Luck.
P.B.
Oct 15, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Downloading from hdd to dvd+r ?
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Jul 28, 2007 | Philips DVDR3455H/37B
EZ Dupe (EZD-1TCDSO) CD-RW Burner Logo
Top EZ Dupe Computers & Internet Experts
Gene
alwaysreddy
Are you an EZ Dupe Computer and Internet Expert? Answer questions, earn points and help others
