Question about Whirlpool Ovens
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    Genius:
  • 1,416 Answers
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Posted on Oct 10, 2010
    Had cleaned GE oven yesterday using SELF CLEAN and today my oven will not work as it keeps flashing UNLOCK DOOR when the door is already open. Cant use the oven
    There is a sensor/switch that sends a signal that the oven door is locked and that it is unlocked, it must be defective.
    Jan 11, 2017 | GE Ovens
    Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
    The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
    May 11, 2014 | GE Ovens
    Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
    Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
    Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
    We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
    try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
    Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
    Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Nov 09, 2010 | Kenmore Ovens
    Hi! I am trying to self clean the lower oven in my built in oven. Yesterday I did the top one with no problem. Today I started it & it seemed to go correctly but it has been making clicking noises. The...
    heatman101
    Aug 24, 2010 | Thermador SC302T Electric Double Oven
    I self-cleaned our oven yesterday. After waiting
    in order to get the door open you can remove the door locking motor and turn the locking shaft.
    there could be a problem with the excessive heat from the oven during the cleaning cycle check with frigidaire and see if there is any kind of recall for this problem
    Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven does not heat. Broiler and stove work. NO gas smell.
    could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
    Feb 02, 2009 | GE Ovens
    Thermador SM272 - Oven not heating after self clean cycle
    Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
    Sep 23, 2008 | Thermador Professional Series PO301...
    Ovens Logo
    159 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal DeAngelo
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
