Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Mitsubishi 46" Rear Projection TV
My TV goes out of alignment and I can temporarily fix it my smacking it on the side (really, no kidding). It's OK for a while, then shifts back out of convergence. Does this indicate a loose connection or something that I can possibly fix myself.
    Scholar:
  • 167 Answers
Hello it need to be resolder . on some of the connection's have dry scoket.!!! sound's like to me.!!! seen this probulm over and over. in set's that get used a lot.!! and ya . you can try it your self al u need is a solder iron not over 40 watt's and some rosin core solder 60/40. u can get a raido shak. cheep. and go over your board. looking and any connection that look's oxzdoise. make sure that u unplug your set first. let know if your going to try too.!!! ok
Posted on Jun 13, 2008
I have a Mitsubishi WS55809 that I purchased in 2002, and my kids have been using it for gaming. As they are playing, the screen convergence will change constantly from a normal image, to a "bow...
Unless you've moved the unit lately, or the kids have treated it roughly, it's probably not the mirror, which is fixed in place with screws on this model.
You can also take a look at this website here, which describes some solutions to bowing problems, specifically replacing the convergence ICs. However, this is expensive, provided you can still find parts, and probably isn't your problem, anyway.
Since whacking the unit fixes and un-fixes the problem, it's more than likely a connector that's loose. If you know your way around the inside of a TV, you can unplug, clean, and re-plug the various boards and connectors, especially the convergence and deflector boards. That will likely solve your problem
CAUTION: If you don't know your way around the inside of a TV, DON'T OPEN IT! Even after unplugging the TV, some of the wires inside will have enough voltage to cause serious injury. Better to be safe than sorry.
Feb 28, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
My picture is blurry, re-setting the convergance helps
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Mitsubishi WT-46807 46" Rear Projection...
The picture gets a bow effect, smacking the side of the tv helps temporarily. Is it the bulb, wiring problem or what
loose solder connections on your convergence ics ..you should get this fixed quick..the loose connections on the convergence ics can short them out..this will be more expensive to repair then a simple solder job.
Dec 16, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Wt-46809 has convergance issues
Replacing the Convergence IC's should do the trick. But it is not a easy repair do to the disassembly requierments. I would recommend calling Mitsubishi at 18003322119 to get a local service facility to come out and give you a estimate to repair.
Jun 21, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Color alignment kpwt500 tv
i would have a shop reconverge it.thats going to be the easiest way to get the picture back the way it should be.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Covergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 30, 2008 | Mitsubishi WT-46809 46" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
