Question about Acer Aspire 5100 Notebook
Acer Aspire 5100-3583
I have to replace my hard drive but can't get Acer or Western Digital to help with identifying if a hard drive I seleted fits. I found a Western Digital Caviar SE 160GB Hard Drive - 7200, 8MB, SATA-300, OEM but have been unable to determine if this will work. Please advise or make a suggestion on a hard drive.
  • wishf Nov 13, 2008
    I need to replace the hard drive on my Acer Aspire 5102 notebook. This will be the third time it has been replaced since I bought it two years ago and this time I'm replacing it myself. Which hard drive should I buy and how hard is it to replace the hard drive? My brother was telling me the original hard drives that were installed were proving to be problematic for most and typically resulted in having to chenge them out. I don't want to come across this problem again soon, so I'l like to go with another manufacturer with a strong reputation for what they make.
You need a PATA drive, not a SATA drive. The difference is the connection. According to what I read in the manual I believe the max size hard drive is 120 gig. It comes with 80 gig.
Posted on Jul 31, 2008
    Sergeant:
  • 458 Answers
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
Posted on May 31, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Thanks for the rating. I have had the same problem with companies when I contact them. The person on the phone is usually giving you an answer that their computer gives them when they input your question. This sux because when you can you want them to know the answer. The problem is that you sometimes know more than they do. The best way to see if a hard drive works is to try one and see. I called Toshiba the other day about the same thing. They told me that the laptop could only use a 100 gig hard drive. I have a 250 gig hard drive and put it in the laptop and the BIOS could tell what size it was. This told me that it would work. Always try another hard drive and see if the BIOS recognizes it if you can. If you can't do that, then you are better to go back with one the same size as you had. Most manuals will tell you but some do not. If you know someone that has the same kind of hard drive, you can use it to do the test. Just remember, the brand usually does not matter unless someone has done something to make other brands not work. I have never seen this, but it could happen. If you have any more questions, feel free to ask me. I check in at least once a day.
Scuzzy hard drive changing to Western Digital
You can find all information and drivers here.
Opening The Case
Before you open the case, turn your computer off and unplug the power
cord from the wall outlet.
a) Gently lay down the computer on a flat surface to access the side panel of
the unit.
b) Push the case lock to the right and pull the side panel toward you to
remove the side panel.
Now you have access to the harddrive to exchange it.
Nov 25, 2011 | Acer Aspire E360 PC Desktop
THE ACER ASPIRE 5735Z WITH WIN 7 WILL NOT FID IT
Hi, Thanks for using fixya.
Western Digital 320 GB Hard Drive Is for a pc not a laptop so it won't fit it.
Terry
Feb 14, 2011 | Western Digital (WD3200JS) 320 GB Hard...
Acer Aspire 5570 getting SMART failure error on HDD
Definitely a hard drive problem, you'll need to replace the drive and reinstall all the software.
Apr 04, 2010 | Acer TravelMate 507T Notebook
My ACER laptop does a system check every time I start it up
I would be concerned as well. Sounds to me like a hard drive that is about to go bad. If you can get into windows, click Start > Run > and type "CMD" to open a command prompt. After that enter CHKntfs /X C: and press enter. That should stop the startup check disk from running.
I would also recommend that you run a defrag, and also use the Western Digital DLG program, it will tell you if you have any disk errors and if you need to replace the Hard Drive. Here's the link:
http://www.filecluster.com/System-Utilities/File-Disk-Management/Download-Western-Digital-Data-Lifeguard-Tools.html
I just used this tool last week to fix a customer's laptop for them. Works great and is on the money.
Mar 15, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire Hard Drive failure
any laptop Hdd will work as long as you know whether it is SATA or IDE.
The casing around the Hard drive will be different, but can easily be put onto the new drive, but be careful of static and dont drop it
Feb 02, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
120gb Hard Drive
I'm going to say that the drive is mislabeled. I've ran into this before with Western Digital two or three times, and quite a few times with various memory chips. Contact WD support, explain the problem, and their usually pretty good about getting the right one to you.
Aug 14, 2008 | Acer Aspire 5050-3242 Notebook
Acer hard drive
Hi, the problem is one hard drive ie the 1/3 one is a SATA hard drive, the other is IDE.
to set them both up you need to do this,
Connect the IDE Hard Drive using the IDE cable like before.
With the Acer Hard Drive you need a Sata cable cost about a £1 from any shop.
You connect the sata cable from the hard drive to the motherboard, but on the motherboard you are looking for a small red connection same size as the cable, SATA is on most motherboards for machines that are just over a year old.
Hope it helps.
Have a nice christmas
John
Dec 10, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Acer Aspire 5100 Notebook Logo
264 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
