Question about Nokia N95 Cellular Phone
N95 phne what is, and how do I format my phone
  • 29 Answers
Well, formating your phone has two aspects to it.it could be either formatting your phone itself or your memory card only. formatting your memory card can be done in the memory card program on your phone, but formatting your phone requires you to type in a code in your stand-by screen ( *#7370#) Formatting your phone memory will delete all settings, messages, calendar items, contacts etc.
Posted on Jun 20, 2008
3 Suggested Answers
Raysagem
  • 1017 Answers
SOURCE: Formatting N95 Nokia Phone
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
You could try this, but don't hold much hope:
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know, you need someone to press the ON button.
Or try:
Hard reset code *#7780#
Posted on Mar 02, 2008
my handset(N95) restart if i was capctures the photos.  so what i have do?
Posted on Sep 10, 2008
Hi ash! I have this nokia n95 vodafone with an 8gb phne memory. whenever i try to put or move files into the phne memory, it wont and instead it displays that disk is full although i havent put any files...
If the phone indicates "memory full,delete some data" and you say that there are no more file stored on your phone memory,transfering data even on mass or internal memory which is 8g would not be possible because the phone needs a minimum requirement free space to perform any operation such as taking picture,playing music etc.
All your have to do is reset or format your phone using this two methods.
(Before doing this,make sure all important data is backep-up cause everything will be deleted
1. on your home screen,just type *#7370# ,a message pop up "Restore all original phone settings? Phone will restart" then press Yes, it will ask for the lock code. Enter your desired lock code if any,otherwise the default code is 12345 and the phone will restart.your phone is now on default settings. DONE.
2. Another ways is by going to Menu > Tools > Settings > General > and locate Factory settings, once you open that option, a message also pop up to restore your phone settings and ask for a lock code as what method 1 did.
Now if its all ready,start and enjoy your phone features.
If there's any problem, just reply and i will get back to you as i received the comment.
Hope this method helps you.. Thank you for visiting FixYa.
Jul 03, 2011 | Cell Phones
There is a problem in my phne the music player doesnt get opened
better try formatting it by pressing * key , number 3 key with call green key while switching it on.!!!
If this solution helpful/useful for you please rate mysolution. THANKS FOR USING FIXYA.
May 17, 2011 | Nokia N95 Cellular Phone
I downloaded wwe aftershock my pc, but when i try to install it , it breaks up into seperate folders and i cant install it. so i practically cannoy get it onto my phone (Nokia n95 8gb)
Hey xenonhide...... Is N95 an symbian phne...does it support sis. files ??? if not then ths game wont wrk.....
If it is a symbian phn u need to do is... extract the files frm zip file then transfer those folders (Apps, Libs n prgrms) inside the system folder in ur mobile(if ur cell dsnt show system folder then do "show hidden files") via computer...or u can do this with FExplorer
Oct 10, 2009 | THQ WWE Aftershock for N-Gage
I want to change my language on my nokia N95 8GB by d way i bought my phne in china. My other problem is how can I use the map the language is in chineese form so there is no use at all, dts why I'd like...
Nokias have somehing called a "product code". this tells the phone which regoin it was made for and which software it was loaded with. So you need to change your product code to US or Euro version and then flash your firmware with the corresponding flash. Programs like NSS and NOKIA SOFTWARE UPDATER can help you do this. However you need to know what you are doing. Slecting the wrong product code then flashes the phone with the wrong firmware killing your phone. However this can be done easily by an expert. I would suggest you contact or send your phone to one.
Mar 10, 2009 | Nokia N95 Cellular Phone
N95 8GB: General Mass Memory Full: Unable to send messages
hi there...try to format your phone...enter this code *#7780# then after that try to check things out if its now working well...hope this will help you
Feb 11, 2009 | Nokia N95 Cellular Phone
Phone
N95 is the perfect phne
Jan 11, 2009 | Nokia N96 Smartphone
when did you get the phone . mabey you texed too much
Dec 29, 2008 | Nokia N95 Cellular Phone
Format N95
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Billman87
Nov 16, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
