Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
My vacuum is a Kenmore Special Edition with a Power-Mate 12.0 AMPS wand. I ran over the edge of fringed edge of my living room carpet and immediately turned off the vacuum. Although I have removed the fringe pieces from the wand head and I have pushed the overload protector reset button on the wand, the wand brush will not turn. Help- it's the Thanksgiving weekend and guests are coming soon! Thank you.
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
SOURCE: No power to head of Kenmore Progressive canister vac
The extension wands are defective and have trouble with their plug connectors on each end. The power head has a reset button on top right but no lights mean no power which means the wand isn't connecting the power to anything.
Sears has a new replacement -- too bad it isn't recalled so you could get it for free ($106.59 + tax + shipping). 2nd sweeper -- same problem.
1st sweeper: I just took needlenose pliers and pulled connectors out a little further (Too bad I can't seem to make the 2nd sweeper work with this easily. It might be one of the connectors or the wiring harness inbetween with a break.) Can't buy the wiring harness for this or connectors, just the wand.
If anyone has a working wand you want to sell me email me at hiwhatsnew@hotmail.com. Thanks!
Posted on Jun 12, 2008
Agent Don
  • 310 Answers
SOURCE: Hi, I have an electrolux Ambassador
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=678083
Generic problem for all Vacuums
Hi, I have an Electrolux Ambassador
Posted by greenforest on Jun 17, 2008
Hi, I have an Electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the Electrolux stop (has happened before) and when I pressed the reset button, the motor is on but the wheel does not spin. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 17, 2008
advacak
  • 125 Answers
SOURCE: kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Posted on Dec 03, 2008
  • 134 Answers
SOURCE: Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
While using the power mate rug part I caught a small rug and the vacuum would no longer pick-up .
Check to see if there is a reset button on the head. This protects the machine for times like you described. When something jms up the reset button will turn ofdf th machine. Simply push the reset. Hope this helps, Chris
Feb 07, 2011 | Kenmore Vacuums
My power mate keeps losing power. As I am vacuuming, it surges off and on. The rest of the vacuum works perfectly fine. help!
Remove the wand from the telescoping pole, and look at the two holes in the wand where the electrical connection is made between the wand and the pole. You may see corrosion, which will cause the connection to be flaky and the power assist to surge on and off.
In any case, a good bet is that the wire harness in the wand needs replacing. It's about $15. (P/N KC37GBZTZV06) You'll have to take the wand apart - 3 screws and some judicious prying - to replace it.
Dec 28, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
We have a Kenmore canister vacuum cleaner. the carpet cleaning attachment, I think is called the power mate has a beater that is intermittently working now
Your hose could be bad. The wires frequently go bad up by the handle switch. also could possibly be the wand, those go bad. You can check that by attaching your powermate directly to the nozzle without the wand and see if the same problem is there. Do you have the mini powermate also? the one that is usually mounted on the wand. If so plug that in directly to the hose and see if you have the same problem. If that tool works fine then the problem is in the powerhead.
Jan 03, 2010 | Kenmore 23812 Progressive PowerMate Bagged...
I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Carpet attachment
Check the plug ends at the top of the wand and the plug going into the hose handle, also at the bottom of the wand. It sounds like they may be burnt, if so they will need to be replaced. One cause of these connections going bad is not turning the power head off when connecting or disconnecting. Therre are other causes, the switch in the handle is going bad, also some of these cannisters have a relay mounted by the vac motor, sometimes they go bad.
Mar 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Carpet function rollers don't turn
Most likely a broken belt. If the brush roll is turning freely, then check the belt.
Mar 02, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
145 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
