Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
I purchased a used upright freezer Fridgiaire model FFU2065,, below the door on the vent grill,, there is a orange light, (then a on off switch) followed by a red light. Can you explain what position the switch should be in.? The orange light stays on but the red light doesn't respond to the switch. Thanks,, Don K.
  • 1,531 Answers
The red light is a temp warning light and will not respond unless the temp goes way above the set temp
Posted on Oct 13, 2010
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
check and empty the drain pan, you should be able to gain access by removing the vent grill below the door if there is one. The pan is under the unit somewhere. There is also a drain tube, make sure its not blocked with ice.
Sep 06, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
What is the orange light for at the top of my freezer
Your freezer seals on door are bad causing it to ice up and the light is telling you to defrost,these models have a design flaw that causes this,seals around door have to be replaced to fix.Call your local appliance company and see if they can order you some new seals.
Oct 27, 2012 | Frigidaire 20.3 cu. ft. Upright Freezer...
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Mar 20, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Where is the 9-volt battery located?
Welcome to FixYa.
The 9vdc battery should be just below the door on the right hand side, ( from facing the front ) some models have it behind the toe panel/grill in said location...lower r/h.
That should answer your question. Thanks for choosing FixYa.
Please take a moment to rate the info provided here today.
regards,
macamrkus :)
Aug 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
POWER LIGHT FLASHES ON / OFF
You need to install or change the battery for the power out freezer alarm. Mine was just doing the same thing. I looked on the web for the answer and couldn't find it. Opened the door to look for the model number and there was the diagram for the light flashing codes. Mine's battery compartment is in the grill on the bottom (right below the door) on the left side. Takes a 9v battery. I had a power outage recently and it must have killed the battery after beeping for several hours.
Mar 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
704 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
