Question about Milwaukee Tool 49-24-0200 AM/FM Radio
I need to know how to change the fuse in a miluakee jobsite radio.
Locating the serial number for my Bosch PB360C Jobsite Radio
If it isn't on a tag on the bottom then it is likely missing.
Sep 23, 2016 | Cars & Trucks
Milwaukee 2792-20 M18 Jobsite charger/radio not working
sadly there is no help for things bought from Craigs list try contacting milwaukee thru their website
Aug 29, 2016 | Audio Players & Recorders
Hallo my bosh pb360 s not work only the outlet have power
You blew an internal fuse. There are two glass fuses inside. Unplug the unit, flip it upside down, remove screws and four from roll cage so you can take it apart. Inside you wil see both fuses and will be able to determine which one to replace. Be careful to make sure subwoofer wire is connected before re-assembly!!!
Nov 12, 2014 | Bosch Power Box 360 Jobsite Radio PB360S
Radio will only operate with a battery
inside the radio you have tranformator that downgrade from 110\220v to 12v
its seem like it's not working in your boombox
injoy
Dec 13, 2013 | Bosch Power Box 360 Jobsite Radio PB360S
MILWAUKEE JOBSITE RADIO'S CLOCK DISPLAY WORKS BUT NO RADIO
if it work on battery and didnt work on 120 volt,the transformer is dead,i see a lot of radio with dead transformer.
if it dont work with battery and 120v,the control board have problem.
Oct 18, 2012 | Milwaukee Tool 49-24-0200 AM/FM Radio
Max volume is way too low
what causes that issue is that your treble and bass are probably turned all the way down. just adjust those up to max and your unit will be alot louder.
Jul 18, 2009 | Bosch PB10-CD Radio/CD Boombox
Milwakee job site radio not working
There is no fuse, have a look at the transformer.
Dec 02, 2008 | GE Superadio III AM/FM
Milwaukee Tool 49-24-0200 AM/FM Radio Logo
115 people viewed this question
Top Milwaukee Tool Audio Players & Recorders Experts
k24674
Andrew Taylor
Andrew Taylor
John91
John91
Level 1 Expert
Are you a Milwaukee Tool Audio Player and Recorder Expert? Answer questions, earn points and help others
