Question about Sony Playstation 3 (PS3) Console
Both my tv and ps3 turn on and work well. they are connected by a HDMI cable but the tv seems to be unable to pick up the ps3 and so theres no picture or sound. I have tried to turn them both of and disconnected them but this has no effect.
  • 30 Answers
Hold power button for two peeps --> will reset video setting to lowest, restart and it will show up
Posted on Oct 10, 2010
HMDI 1 and 3 do not work (why) ?
Since you did not mention HDMI 2, I assume you have that connected to something else, and that is working properly. The following procedure is based on that assumption.
First, turn off everything connected to the set, and the TV itself. Disconnect the HDMI cable from whatever is going to HDMI 2 (leave the TV end alone for now) and connect it to the PS3. If the PS3 shows up on the TV, the problem is most likely a bad cable. To verify, turn off the PS3 and the TV, then move the known good HDMI cable to either HDMI 1 or 3. If the PS3 works on those also, the HDMI cable you had originally connected to the PS3 is defective. I know there are some bad ones out there; there is at least one lot with a right-angle connector on one end and a straight connector on the other that has a very high failure rate.
If the PS3 does not work with a known good cable to HDMI 2, then the PS3 has a problem. Try using a component (RGB) or composite (yellow end) connection to narrow down what the issue is.
If HDMI 1 and 3 do not work with a known good cable or any input source (DVR or cable box), then the HDMI switching circuit inside the TV is defective. Since the set is "new" that would be a warranty issue.
Jan 03, 2015 | Westinghouse 55" Class - LED - 1080p -...
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
PS3 no longer communicating with TV
The problem is with your PS3 itself.
If it's still under warranty, take it back.
May 30, 2009 | Sony Playstation 3 (PS3) Console
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
May 24, 2009 | Sony PlayStation® 3 (60 GB) Console
HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Apr 30, 2009 | Televison & Video
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
