SANYO AWD A845ZT top open drum washing machine, its brand new but its door is automatically locked. how it can open?
I can't unlock my washing machine, I don't know why. It normally opens automatically after it has finished.
Apart from a faulty Door interlock could be water stiil in the drum make sure its empty and electrics are ok firstly
Feb 22, 2011 | Washing Machines
Its a whirlpool 6th sense washing machine no awd/d 5706, it stopped with a full load in 8 minutes before end time no numbers are flashing up but it wont do anything , i have opened the door took washing...
i have a whirpool 6th sense washing machine and it wont spin and the timer stays on 14 minutes remaining have you come across this problem and do you have a cure
Jul 29, 2010 | Whirlpool Washing Machines
My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door will not open. lock handle floppy.
take top off and see if you can feel for the door peg sticking thro the interlock and operate by hand.
also, you can chew away the door handle and operate the door peg with a small screwdriver.
the door handle kit will need replacing anyway
Sep 11, 2008 | Zanussi WJS1397W Front Load Washer / Dryer
Zanusi washing machine
If you get rid of the water from the drum chances are that the door lock will then release. Try taking the outlet pipe and laying it down over a bowl to catch the water. If it empties then the door should open in a minute or so. If it does not empty then the pump is probably blocked, and you would need to remove the hose from the bottom of the drum where it connects to the pump, but make sure you either take it outside to do it, or you do it over a bowl to catch the water, and have plenty of towels to mop up the flood. It sounds like the drum bearings have gone and the bits have gone into the pump, or filter.
Mar 05, 2007 | Zanussi FJ1254W Front Load Washer
DOOR WONT OPEN
I'm afraid I don't have a solution, just the same problem. Exactly this has just happened to me and I don't know what to do. Calling out an engineer will be too expensive and in the mean time, I can't do any washing. Have you had any success yet?
Jun 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
224 people viewed this question
Top Washing Machines Experts
