Question about Maytag MDB7100AWB Dishwasher
HOW TO REMOVE SPRAY ARMS ON MAYTAG DISHWASHER Model # DWU7402AAE SN 37901989SF
  • 641 Answers
SOURCE: Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Posted on Sep 10, 2007
eagle338
  • 4889 Answers
SOURCE: Dishwasher will not spray water from arms
Check for utensils or pot handles that may be hanging below the bottom rack and interfering with motion of spray head.
Clean holes with toothpick.
Check temperature at hot water faucet with meat thermometer. If below 120°F (49°C), turn up thermostat on hot water heater.
Posted on Oct 19, 2007
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
fluxchrizm
SOURCE: Maytag dishwasher with a spray arm that is stopped
We have a dwu7400 so i'm not sure it is the same, but above the top arm you should see a serrated ring (looks a bit like a flower petal) and that should spin off and the arm should come with it. There's a snap that holds those pieces together that if you squeeze it with your fingers you can get it out. Just reverse that to put it back together.
Posted on Nov 08, 2009
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
I have a Maytag MDB4709AWS dishwasher that's not doing a good job cleaning dishes. Even on heavy duty cycle I still have small particles stuck inside my cups and on top also. I wanted to remove the inside...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 09, 2010 | Maytag MDB7100AWB Dishwasher
Maytag dishwasher wands don't turn
Here is a tip about why the dishwasher arms may not be turning...
Dishwasher Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
May 22, 2010 | Maytag MDB5100 Dishwasher
The spray arms (don't know the technical name)are clogged with hardwater build up. How do you remove and clean?
Hello. No need to remove just spray them with CLR http://www.shopclr.com/index.php?page=Category.Browse&externalCategoryId=32582&leadsource=PS144&s_kwcid=TC|6221|clr||S||3734539849&gclid=CJzr_Z2m2aACFVZS2godliARDg
And let em soak for ten minutes then run the dishwasher for ten minutes. Repeat the CLR spray, run the dishwasher etc. Joe
Mar 27, 2010 | Maytag Jetclean II MDB8551A Dishwasher
Maytag eq plus, not cleaning properly, seems the
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
I have a Maytag MDB9100A leaving food particles
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
We have a Maytag dishwasher. The first thing I noticed was the soap oozing down the door, but it also appears that the spray arms aren't moving. The water is sitting in the bottom of the dishwasher.
Depending on your model number, Maytag dishwashers on one model have combined drain pump & spray arm pumb. On other Maytag units these pumps are stand alone pumps. Check to make sure that:
1: drain hose to drain pipe(disposal) is open and flows well, do this by disconnecting the hose from disposal end and lay flat (in a pan) on floor and see if water comes out, if it does hose is clear of gunk.
2: Check garbage disposal inlet tube where drain hose connects, if your recently installed disposal then you may have forgot to remove plastic plug,
3: Turn spray arms by hand and make sure they spin freely,
4: make sure that when you close the door it latches and you can hear the pump running.
If all the above are ok, then you have a drain/motor gone down and will need to replace it. Give us a model number and we can advise better where else to look.
Nov 12, 2009 | Dishwashers
Soap
1. You have poor pressure coming from the pump. fix this by removing the racks from dishwasher and removing/cleaning the intake filter to the pump. It is located on the floor of the dishwasher. Use a wet vac if you have it to clean the entire area and anything that might be stuck down in the pump. you would be suprised what you find doen there. Don't be afraid to remove a few phillips screws to remove a cover to the impeller. After this all should work better/cleaner AND soap dish will be washed out too.
2. make sure dishes are not stacked to block the soap dish from water spray arms.
3. remove spray arms and clean them out, especially the spray tips. Hard objects will stick in their spray tips.
Good Luck
Jul 29, 2009 | Maytag DWU9962 Dishwasher
Oct 19, 2007 | Dishwashers
Maytag MDB7100AWB Dishwasher Logo
75 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
