Question about Garden
We have a pk5020 puma air compressor that will star slowly then come to a stop. It flips the electriccal on the motor.
  • follettepott Oct 09, 2010
    Thats the first thing we did, they check out OK.
    What next.
  • 43,501 Answers
Before I would do anything else I would change the capacitors on the motor...
It sounds like one or more depending on the motor of the capacitors are bad...
They are not giving the motor enough kick to get it going up to speed...
heatman101
Posted on Oct 09, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Oct 10, 2010
    Does the motor run with no load? If not then the motor is bad is so check all wire connections for a poor connection which could cause low voltage. Is the relief valve working so that the motor is not starting under load?
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
How do I fix my pressure switch on my puma 6060 compressor
Need some details, exactly what is it doing or not doing incorrectly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
I need to fix a leak in my pressure switch
You don't repair a pressure switch, you replace it.
Nov 28, 2014 | Puma Air Air Compressors Puma Air PK6060V...
What compressor oil do i need for my puma air compressor
Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
How do I wire my puma 220v sigle phase air compressor with s-p40t motor starter?
You contactor /motor starter has connection for up to three phase /L1 thru L3. You will be only using L1 and L2 connectors for power-in/ line and using meter find cross connector for connecting load / motor (usually white and black or red from the motor). The contactor has a push button to test your work (use meter to test before actually wiring up motor and line). The contactor is controlled by separate switch (usually pressure switch on the compressor) using proper voltage as required by magnetic switch of s-p40t. Good luck
Apr 06, 2014 | Puma Air Air Compressors Puma Air PK7060V...
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Sep 29, 2013 | Puma 3-HP 60-Gallon Belt Drive...
I have a Puma air compressor model # DD-2004v. I have replaced the piston in the compressor because I was told the one had gone bad. In order to get the new piston up in the compressor I removed the fan...
Hi cleancutc844...
Sounds to me like the fan is running in the wrong directions and not cooling the motor as intended.
Reverse your wires to to reverse the rotation of the fan motor and make sure it is pushing air over the motor to keep it cool while running.
Please take time to rate me
Sep 17, 2011 | Puma Air Tools & Compressors
I have a PUMA air compressor that has been running fine until this morning, it will not run, I have power (220 ) to the wires at the pressure switch and the reset button was not tripped, motor and...
If you remove the fan belt and the motor runs without a load,
one of your motor capacitors is bad. some motors take one
capacitor, some take two. the capacitor is what helps the
the motor give that extra torque to run the compressor pump.
good luck!
Jul 17, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My puma air compressor after use will get hot and shut down then i have to wait until it cools down (half hour )then i have to hit the reset button on the electric motor
the motor is working too hard or the power source is not adequate or you are using a extension cord never use a extension cord for a air compressor you will destroy the motor over time use longer hose and plug it in to the outlet directly
Jul 06, 2011 | Puma Air Tools & Compressors
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
