Question about Microwave Ovens
The burner indicator light on my GE Range will not turn off? The burners are not on, I've checked several times, how do I get this to run off, I've checked the manual and nothing is listed for this problem in the troubleshooting section. Thank you,
    President:
  • 1,430 Answers
This is usually caused by a failure in one of the infinite switches. The switch may still work properly with the exception of the indicator lite. They are easy to check and replace. Here is a link that should help
Testing an infinite switch
Posted on Oct 09, 2010
I clean the burners and the ignite it is not working if i used a lighter the back tow burners will turn on but not the front ones
Sometimes when we clean the burners we get some debris or gunk into the gas outlets. I always take a toothpick and clean out the gas openings. Be very careful that you don't break the toothpick off in the opening. Once you've done this, use a lighter at the burner and turn on the gas. You should have a flame. Let the flame burn for about 5 minutes to burn off any more "gunk" that may be in there. Also, if your burners have covers, make sure they are in place before you light the burner.
Depending on the age of your range, you might need to clean around the igniter. Some are concealed and you can't reach them. Those that are not concealed can be cleaned by wiping with a soft, dry cloth.
I hope these suggestions help you get your range working again. If they do, please come back to Fixya and rate my advice!
Aug 15, 2011 | Microwave Ovens
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
I have a kenmore elite range model number 790 46809 991 and the burner on both the left and right are acting up. They both show that a burner is on on the control panel (not surface indicator) and the...
Hello gralexander,
The problem you are experencing is with you control switches. The cheapest place i can find the switch is from searsparts direct. Here is a link to the webpage http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046809991/0583/0124160/P0050380/00001?blt=06&prst=0&shdMod=79046809991
You will see a diagram in the top left side of the page use it to locate the switches that are bad and order them from sears. You may also need the burners to check them you need a continutity tester.
1. Remove the burner from the socket
2. Take your test and touch one probe to each side of the burner.
3. If you have continunity then the burners are good
4. If not you will have to order burners as well.
Changing the switches:
1. Unplug the range
2. Remove the back panel where the switches are.
3. Remove the knob from the front
4. Remove the screws from the switch you are replacing (Due one at a time)
5. Move the wires from the switch to the corresponding terminal on the new switch
6. Replace the switch and screw in place
7. Do the other switch
8. Reinstall the cover on the back of the unit
9. Plug in and try
Doing all of the above steps should fix the problem that you are having. Please make sure that you install L1 to L1 and L2 to L2 on the new switch other wise you will cross wire it and the rest of the switches will short and need to be replaced.
Thank you for choosing FixYa.com. If you have any other questions please post back to this thread and I will do my best to help you with your Range problem
Justin
Mar 10, 2011 | Kenmore 63252 Microwave Oven
I have a GE 4 burner self cleaning range. it was installed new. I have lived here since 2006 and was the first and only occupant. The stove is lightly used and kept very clean. I prefer my microwave and...
Are the burners warm all the time? If so then this is a problem. Perhaps when you had your incedent were you leaning forward and pushing on the front controls? Or was the container pushing on controls on the top? .....Pushing on the controls can case them to get hot.
YES, you need a GE professional to look at this.
Good luck,
Shawn
Jan 30, 2011 | Microwave Ovens
I have a GE Range model number JBP72DM2BB. The front main burner stopped heating up. Is there a quick fix to this?
I ASSUME THIS IS ELECTRIC. REPLACEMENT BURNERS CAN BE BOUGHT AT MOST MAJOR HARWARE STORES. THEY ARE EASY TO REMOVE AND REPLACE. THEY SIMPLY PULL OUT, LIFT THE BURNER AND PULL TOWARDS THE OUTSIDE OF THE RANGE AND IT SHOULD SLIP RIGHT OUT, THE REPLCEMENT SLIPS RIGHT BACK IN.
Nov 26, 2010 | Microwave Ovens
Hi, MY name is Ben I have problem with my Kenmore (GE) gas range. the oven does not start up...I've replaced the igniter, but no luck. I measured the voltage across the the two wires at the inigter and...
A burner works only intermittently If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 09, 2009 | Microwave Ovens
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Vent Fan
The only thing I did was to unplugged; turn off all the burners; and let everything cool off. I guess I can't have all the burners on at one time since the microwave is 13" from the burners......and from what I read "microwaves placed over the range" should be at least 30" from the burners...thank you, Rose66
Feb 20, 2008 | GE Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
