Question about Sharp R-1405 / R-140 Microwave Oven
2000 HR Endeavor "over the range microwave oven"
I have found out that if I press ******* the upper right part of the door while at the same time pressing up on the bottom of the door, then everything seems to work OK. Does this mean that I need a new door switch? If so, How do I get at the switch to replace it? And where do I get a new switch? Thanks, Glenn
  • Sharp Master
  • 9,098 Answers
It may be a loose or broken door switch mount or possibly a bad switch.
I have attached (via e-mail) our safety, disassembly & door switch files.
Essentially you make sure it's *unplugged*, then remove the outer cover.
Then you can see inside behind the control panel where the door latches go into the chassis.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
Just opening and closing the door a few times while observing closely will show you where the problem is.
I stock these switches and I can send you one for $6.00, or you can get one from a local appliance parts store, or some hardware stores and home centers like Home Depot or Lowe's.
Once you've looked all this over, please let me know if I can help further.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 30, 2008
  • William Miller
    William Miller Jun 03, 2008
    Pardon if this is redundant, but your test shows that you probably have a broken or misaligned door switch holder.
How do i fix my clock from military time to regular time
Hi Tinay
I found this on page 10 of the manual:
"MY SETTINGS
Your new microwave oven can be customized to suit your
personal preferences. Simply press the My Settings
button to configure the following options
No. 3 - Clock display control 1=12HR 2=24HR"
Link to manual page 10 --> Samsung SMH1713 User Manual Turning On The Power For The First
Trust this helps, regards Alan
Mar 04, 2015 | Samsung SMH1713B 1.7 cu. ft....
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave won't heat or turn off unless I press the door
That would be a loose door switch mount, a failing door switch, or both.
See our file on door switch help here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 31, 2010 | GE Microwave Ovens
Unit will only work one time /then you have to wait 10-15min
ge over the range microwaves have this problem . for some reason the plastic sort of melts but not realy (please check hinge for wear and adjust if ness ) , it just gets out of shape from the heat and this makes the switches not work properly . most likely the micro is too close to the stovetop . see your manual about that and you can buy the slideing plastic parts where the switches are , its just big $$$$ if the micro is to close it will happen again GOOD LUCK
Jan 17, 2009 | GE JE1540 Microwave Oven
Microwave removal
We have installation instructions on our site that cover several past Sharp models and may be close enough to yours to help you.
Normally you take the grille off then remove the two screws that would then be revealed. Then unplug it and slide it forward.
But you should check the link - it should help.
What problem are you having with it?
If you have trouble with the control panel, we regularly repair these for customers nationwide with our guaranteed $39.95 service.
Aug 27, 2008 | Sharp R-1874 Convection/Microwave Oven
How to replace a 2000 HR Endeavor "over the range microwave oven"
It sounds like you may have a bad keypad or (hopefully) a simple door switch failure.
When you press Start, if it does not beep, then either the door open switch is bad (not very likely) or its mount is bad, or your membrane keypad is failing.
If it beeps when press Start, and your fan and inside light come on and it counts down, but the turntable doesn't turn and it doesn't cook, then you have a bad secondary interlock (lower door switch with white and gray wires) or its mount is broken or loose.
You can try gently pushing up and down on the door while trying to hit Start. That will sometimes make it try to work.
For this model, neither the control panel frame with keypad nor the separate membrane key sheet is is available, but the key sheet from a different colored model may still be available. I can check into that further if you want.
Door switches are pretty easy to get. They are often held in place by a little tab on the underside of the mount. That can be hard to reach, but not too bad if you're careful.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have the service manual for this model and I can e-mail to you.
If you'd like us to install the keypad, we can do it for $39.95 plus parts.
Please feel free to contact me directly if you need more help.
Please contact me directly and I'll also send you installation info on several Sharp models. That should give you enough info in case you decide to remove it.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 25, 2008 | Sharp R-1405 / R-140 Microwave Oven
Sharp R-1405 / R-140 Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
