Question about Weather King 12AJA6001AH Air Conditioner
My Weather King AC unit model number 13AJA48A01 is freezing over. What can I do to fix it.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. First be sure that the blower is working next make sure the filter is not plugged. If these two things are okay then you probably have a low freon charge in the system. Which also means you have a leak so I would have the system leak checked and repaired before having someone just dump freon into the unit as its just going to leak back out.
Posted on Oct 09, 2010
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
AC unit model number 13AJA48A01,serial # 7404N220603611 still under warrenty
You Need to contact the manufacturer with your receipt to check warranty status
Aug 17, 2012 | Heating & Cooling
What ton is my old Luxaire AC unit? it is model EESQ36
Sure but you need ot have an AC man to replace it and vac down the system plust change the dryer/reciever.
Jun 12, 2009 | Weather King 10AJA3601AH Air Conditioner
How much is a compresser for weather king ac unit
Be happy to help you and find an answer. Did your compressor burn out? What are the numbers on top of the compressor? How many BTU's or What is the the size? Tons of BTU's?
May 16, 2009 | Weather King 10AJA1801AH Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
Freez up at the tube going to the fan blower unit
it is either low on freon or the airflow is blocked. check your filter first. then see if the coil is dirty. saying it needs a new coil because it is freezing is an expensive guess unless he did a freon leak test.
Oct 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Weather King contact info
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
Sep 03, 2007 | Weather King 10AJA6001AH Air Conditioner
Weather King 12AJA6001AH Air Conditioner Logo
276 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
