Question about Vacuums
My Hoover Dual v lets out too much solution and water.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=634300
Generic problem for all Vacuums
Posted by evertonoompa on May 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have 2 problems, #1. The trigger assm may be loose or broken and is not releasing the solution from the water solution tank or #2. The valve under the water solution tank could be shot or broken. If so, then the water solution tank is one assm and you would need to purchase a new or a good used one to replace. Please, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 30, 2008
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover f7411-900 steamvac dual v, water heating unit repair
The element is burned out or the sensor is shot. When there is no water present a sensor is supposed to turn off the heating coil. This sensor is most likley fail safe, meaning if it is broken it wont turn on the heat because it doesn't know if there is water or not. Or the coil itself is fried. Somtimes running it for too long, or on a long extension cord will cause them to fail.
Oct 08, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover STeam Vac Dual V. Replaced the water tank-no problem. but water still pours out through the bottom. when idle, when off, when running. dont need to press the lever. Help!
Te dual V models have an electric pump and 2 solenoids that control the soap and water to dispense. The problem you describe, sounds like the water solenoid is stuck open. and would need to be serviced by a repair shop.
Oct 07, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Vacuums Logo
80 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
