Question about Sharp LC52SB55U LCD TV
Screw size for mounting sharp 52 lcd model LC52SB55U on the back for a wall mount
SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Posted on Oct 11, 2007
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
dsacco86
  • 1077 Answers
SOURCE: HAVE A SHARP 52" LCD #LC52D65U AND I CAN'T FIGURE OUT HOW TO REMOVE THE STAND SO I CAN MOUNT IT ON MY WALL. PLEASE HELP ME
On the back of your TV, there are 4 long hex bolts. It should have triangles pointing towards the holes. Take the 4 long hex bolts out and the stand itself should slide out with no problems.
Posted on May 21, 2009
SOURCE: I need to purchase an owners manual
If it is not on the Sharp usa web site, try the Sharp canada web site. I found mine there.
Posted on Jun 09, 2009
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
Screw size for wall mounting of Sharp LC22DV24U
If you mean from the wall mount to the tv, that is usually embossed on the back by a screw hole usually five a Max 10 or something similar. If you mean to the wall that depends on the type of wall material. Use high quality anchors. Your local hardware store should be able to help you choose what is appropriate for your wall material.
Jul 05, 2016 | Sharp Televison & Video
Screw size for wall mounting for Phillips 32inch. What is the screw size on the back that you would use to mount tv to wall
Get in touch with Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Feb 28, 2015 | Philips 32PFL5332D 32 in. LCD Television
Bolt size for wall mount to fit new sharp LC60SQ15U
It will be a metric bolt. They very from model # to model #. Don't get them too long as they could go past the insert and into a PC board!
If you were too Google your model # you may just fine what Metric bolt it would take to mount it. Any good hardware store would have the correct metric bolt or screw for you.
Dec 07, 2014 | Sharp AQUOS 52in. LE820 LED LCD HDTV
What size mounting screw for a Vizio Model VO47LFHDTV30A
Are u trying to mount it on the wall ?
If so. Buy a universal **** it come with all the screw
Or call Qcwireless thay can get thm for u
Oct 11, 2014 | Vizio L32 32 in. LCD HDTV
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
What is the size of the 4 screws on the back of the lg 32ld350 tv?
Remove the 3 screws from the base, these screws are mostlikely metric M4/.70 pitch 3/4 inch long. these are the screws are the matching screens for the wall mount. You will have to buy 1 more. Also 1/8 mini fender washers maybe required to hold the bracket to the back of the TV due to the slots.
Hope this helps.
Jun 30, 2010 | Sharp LC52SB55U LCD TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
May 21, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Jan 18, 2009 | Sharp LC52SB55U LCD TV
Sharp LC52SB55U LCD TV Logo
307 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
