Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
Hot water temperature fluctuates on my grohe shower, but my other bathroom does not have this problem. We have a tankless hot water heater so I suspected it first, but since the other shower works great what about the grohe could be causing the problem?
gary1121
  • 332 Answers
SOURCE: Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Posted on Jun 06, 2009
gary1121
  • 332 Answers
SOURCE: I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Posted on Jun 21, 2009
gasman44
  • 83 Answers
SOURCE: my thermostatic concealed shower valve only gives
If the hot and cold are fitted the wrong way round then the thermostat on the shower unit cannot operate properly!
Most thermostatic mixer showers have a 'bi-metallic' thermostat, if you supply the hot to the cold and vice versa IT WILL NOT WORK.
It is like wearing the left shoe on the right foot and the right on the left! It doesn't work.
Re-install the hot and cold to the correct supply, and this will sort it.
I hope this helps.
Posted on Jul 08, 2009
  • 35 Answers
SOURCE: I have a thermostat mixer shower but hot water has
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Posted on Feb 19, 2010
  • 3 Answers
SOURCE: Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Posted on Jul 05, 2010
Could my grohe thermostatic shower be letting cold water into my system? Some other taps run cool but the shower is running OK temperature
If you have single handle facute one bad cartridge in the system may be acting like a mixing valve and allowing cold water to mix with hot not allowing water to get hot enough .
Mar 10, 2015 | Grohe Water Heaters
Temperature with my on demand water heater is inconsistent
have a plumber check the installation as it appears that there is a temp control mixer in the kitchen line that should be in the bathroom line
Many states and countries now have made it mandatory the full uncontrolled hot water cannot be used in a bath, shower, wash basin but has to limited to a max temp of 70 C to prevent burns to the skin
May 29, 2017 | Bosch & Tankless LP Hot Water Heater
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Dec 16, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
Bosch 2400E-NG output temp fluctuates
This is a great heater. It is however crucial that it be installed to every detail of the manual. If there is trouble send pictures to Bosch tankless you can call 1-800-283-3787 ask for Bosch Tech support or go to boschhotwater.com click find a contractor and call the closest Bosch Service Provider most will travel.
Mar 04, 2010 | Bosch AquaStar 2400ES-NG
Fluctuating temperatures
Sounds like there is not enough flow in order to keep the burner in the heater firing continuously
Jul 09, 2009 | Rinnai Webstone The isolator EXP tankless...
Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
263 people viewed this question
Top Grohe Water Heaters Experts
Paul Carew
Craig Butler
Craig Butler
ray gallant
Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
