Question about Ovens
Frigidaire Gallery Prof. Series Model FEF389WFCH oven quite working, also, clock quit working... but glass top burners work..weird, huh ?? Is it the main brain and what is the technical term for it ??
5 Suggested Answers
  • 30 Answers
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
  • 3640 Answers
SOURCE: Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
Posted on May 14, 2010
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
Frigidaire oven and broiler stopped working but clock andtop burners work
Hello Friend, this is Z. I am happy to assist you!
I see that both the clock and burners of your Frigidaire range are working but your oven does not bake or broil. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you!
Sep 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery series oven
Check your bottom element with ohm meter.
Oct 10, 2013 | Ovens
Oven burner and broiler burner don't warm at all. Stove top burners work. Clock display normal. When turned on lights indicate oven on and preheating (normal). I have reset the main circuit breaker with no...
Hi Brian, thank you for your post!
Sounds like the either both bake and broiler element may be faulty or a potential wiring failure to the elements. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Sep 15, 2013 | Frigidaire 30 in. Electric Gallery Series...
I JUST WANT TO REMOVE THE OVEN DOOR TO CLEAN THE INTERIOR SURFACE OF THE DOOR GLASS
If you mean between the inner and outer panes of glass; you will regret it. It's likely that both are mounted with a fragile heat-proof mineral (non-asbestos) gasket material that may crumble once the panes expose it.
Apr 22, 2011 | Frigidaire 30 in. Electric Gallery Pro...
May 14, 2010 | Ovens
Oven light is not working
It is most likely to be the bulb which is faulty.
You should be able to replace it quite easily, nornally the bulb cover will turn anticlockwise and reveal the bulb which you then replace , remember to use a high temperature replacement.
Jan 04, 2010 | Frigidaire FGB24S5A Gas Single Oven
Main top crack do I need to replace the entire top?
Hi jerseyfol58,
Hate to say it, but yes. The entire "ceran top" comes as a whole, with the exception of the burner`s.
You might consider purchasing the top but having a pro install it, it is quite involved.
Hope that answer`s your inquiry.
Good luck.
macmarkus :)
Dec 07, 2009 | Frigidaire 30 in. Electric Gallery Series...
My front left burner on elec.range model FEFL67GCA does not work.
If it's just quit all of a sudden then I assume it's burned out.You will have to remove the glass top to get to it. The new burner has two wire connectors that plug in. CAUTION: Make sure you disconnect electrcal power to the stove before working on this!
Apr 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
57 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
