Question about LG Refrigerators
I had a brand new LG frig, model LFC20760SB, delivered last week. The unit worked initially then over the course of of 4 days noticed that the frig was not cold. Turned up the settings and still not cold. Finally called and had a repair man out who said the control board was blown so hhgregg sent me a replacement unit. This frig also appeared to work in the first 24 hours but now after 3 days is not cold. Cannot imagine I got another unit with a blown control board. Any suggestions???
  • judithlosoya Oct 09, 2010
    No I already got a brand new replacement frig and this one seems to have the same problem. What are the chances that I got 2 frigs direct from the manufacture that both have blown control boards?
    Yes there was a frig in this location before. These two were professionally installed so that should not be the problem. I can return but not without stress on me. Is there anything else to check. Apparently no one from LG's repair service can be contacted until Monday and I work all weekend so I cannot get to the store to find a replacement. Alsoin the size I need, not many manufactures make the french door models (minimally need freezer on the bottom). What manufactures do you recommend? I need a frig that is not more then 30" wide and 68" tall
    President:
  • 2,047 Answers
Usually when the first unit went back with a blown control board the tech should have adviced on the possible causes of a blown control board.
The main cause is usually a surge in the power supply which is received by the unit. What you should do is get a repairman to take a look at it again and if the control board is also blown request a replacement and get a voltage regulator for the unit. The voltage regulator should control power surges into the unit thereby ensuring that the power surge into the unit is minimized.
Hope this solution has been helpful?
Posted on Oct 10, 2010
    President:
  • 2,777 Answers
It sounds like this fridge has an internal wiring fault for sure if it's killed two control boards in a matter of weeks. I would demand they come pick up the fridge and give you a new one as it will continue to have problems for sure. Who knows what else could be wrong if you already are having these issues. If it were me personally I would not even want to deal with that fridge, you will be much better off demanding a new one, which you definitely are within your consumer rights to do.
Thanks
Tim
Posted on Oct 09, 2010
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Wow, well I'd say the chances in your case are 100% :). I assume you had a fridge in place of this one before? I can't imagine it is the wiring in your house that is causing this issue. I personally have had very bad experiences with LG fridges, they make great TVs and electronics (which is what they are known for) for their large kitchen appliances leave much to be desired. Is it possible to return it and get your money back at this point and go with another make of fridge?
    I know it's hard to believe, but unless somehow you have never had a fridge there before (in that case it could be your house wiring, but I highly - highly doubt it!) then something is up with the control units they are using in this model :(.
    Tim
HOW TO CHANGE EVAPORTOR FAN AND WHERE IS IT LOCATED NEED SPEC SHEET -
Start with Make and Model? Go to their website and get manuals.
Sep 14, 2014 | Refrigerators
Frigidaire frig. model#FGHC2331PF7 is dripping onto top shelf and the filter has ice cycles and what temp should freezer and frig be
If it's brand new and leaking, call the place you bought it from and have them fix it. As for the temp settings; there is a center default in the freezer and you should start there, the fridge also has a default which should be OK. If you need it colder turn it up in small increments and give it a day before you make any additional adjustments. The "cold" in a fridge or freezer also depends on how much stuff you have in the unit, and how often you have the door open.
Sep 08, 2014 | Refrigerators
The fridge is not getting cold at all but the bottom freezer seams to be fine
Their is supposed to be a fan in the freezer that pushes cold air up into the fresh food side. Is that fan running? Look for frost on the backside of the freezer. See any? A sure sign of a failed defrost system. You would know for sure by unpugging the unit and waiting 4 or 5 days. Then plugg it back in. If frig works fine then in another 3 weeks it will get iced up agian. You could of course unplug the ice box once a week to prevent ice from forming till you could get er fixed.
Jun 17, 2010 | Refrigerators
New Frig Won't Cool
Good day,
If it's brand new, it's under warranty. Have them fix it or replace it. They have no choice.
Apr 28, 2010 | Samsung RFG299AARS Stainless Steel (285 cu...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
LG Frig musical tone-why
the musical tone is generally a door alarm letting you know the door is not closed all the way. I'm not sure about the LG sxs but their french door model has a service pointer about the lights not going out due to a bad door switch. 1st of all be sure your doors are closing properly then the next time you hear the alarm without opening the doors use a putty knife or butter knife and squeeze the seal back from the unit and see if the lights are still on in the refrig. you could have a misaligned door or bad switch..
Jan 21, 2009 | Refrigerators
Water trickeling noise from the compressor area.
If there is a leak in the system you will notice considerable change in temperature of the frig. In most cases, if this is a leak, you will see a builup of oil coming out of the leak as refrigerant has oil in it. You may be able to hear it or smell the refrigerant. What is commonplace in alot of systems is this noise. When the compressor is running, it is biulder pressure inside of the refrigerant lines. There is a low pressure side and a high pressure side while it is running. When the compressor shuts down after achieving the set temp, The system will start to equal the pressure on both high and low sides of the system. Actually the compressor will not start again untill these pressures are equalized or at least close. The noise you are hearing is most likely the refrigerant in the system while the system is equalizing the pressure on both high and low sides. I have noticed that some systems are more noticable than others. Unless you notice considerable change in temp of your frig, it is probably the equalizing of the system. I am not sure what the corrosion on the line would be without actualy seeing it myself but I have never come across a frig that had a leak and didn`t lose all or enough of the refrigerant without it being noticable inside the frig itself. For it to be a leak the temp in the frig should be or very soon will be noticably warmer.
Nov 14, 2008 | Refrigerators
LG DR 165 DVD Recorder problem
hi , how are u friend
i have problem pls can y help me
lg dr4810 afiche in lcd (please wiat )
Sep 28, 2008 | LG DR-4810 DVD Recorder
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
66 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
