Question about Coby MP-C7085 MP3 Player
How do i turn on my coby
I can only turn it on if it is plugged into the computer
  • tansak Jun 12, 2008
    my coby player is not working or it cannot turn on,,it only turns on when it is plugged into the computer,,so how do i turn it on without the computer?
There are no button on the bottom right hand side
Posted on Jun 12, 2008
    Problem Solver:
  • 12 Answers
Try pushing the reset button on the back of the unit. it should be on the bottom right hand side.
Posted on Jun 01, 2008
I just got my Coby Mp3, and i plugged the USB into my computer and the autoplay screen that is supposed to come on my computer, hasnt.
Does you computer detect a new device when you plugged the Coby MP3 player?
If Coby MP3 player has cd driver, better to install it to your pc. Some computer/laptop doesn't detect autoplay when new USB device plug-in
May 07, 2011 | Coby MP828 MP3 Player
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
My Coby mp3 player won't connect to my computer
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
c. Make sure the player is TURNED OFF ! ! !
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
(Found HERE if you have had to format the player)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps
Apr 05, 2010 | Coby MP-610 MP3 Player
Installation
If you have deleted the program from your computer, you should be able to plug the Coby player (TURNED OFF) to the computer and re-install it.
If Coby Manager program is no longer on the Coby player (If you re-formatted the player), you can get a copy of the MANAGER here:
Don't let it throw you that it says it's for the MP822 - it also works great for the MP610
1. Install Coby Media Manager from download
2. Open Media Manager
3. Plug your COBY player (THAT IS TURNED OFF) into the USB port - it will show up in the "DEVICE" tab
Apr 03, 2010 | Coby MP-610 MP3 Player
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
I plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Here are the steps:
I hope that helps.
Dec 25, 2009 | Coby MP-610 MP3 Player
Played in car once. Then plugged in to computer. Now all it says coby on the screen when turned on or plugged in computer. Device manager will not reconize . When not plugged in to computer and turned on...
same problem, only i didnt paly it in car, just around the house for a few min. System , device manager sees it as Other USB device with yellow error icon, so doesnt recognize it, even though 20min before i was moving songs onto it np from same computer. piece of ****
Coby mp605-2g
My Coby MP605-2G is not turning on
Sep 09, 2009 | Coby MP-705 Digital Media Player
My coby mp3 player will not turn on
These just use AAA batteries. Have you tried replacing?
May 01, 2009 | Coby MPC895 MP3 Player
How do I charge my Coby Mp3 player MPC885?
Takes about 3 to 4 hours to fully charge if you have a USB 2.0 port.
Feb 03, 2009 | Coby MPC895 MP3 Player
Coby MP-C7085 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
