Question about Nintendo Wii Console
Wii console error has occurred comes up after reading disc Have cleaned the disc as recommended but still happens. Was fine yesterday this has only happened today what do you recommend I do
  • simoli May 30, 2008
    An error has occurred message always comes up when putting in games...all games. I ejected the games, turned off the console, unplugged from main for a while and then try again but same problem appears again and again.
  • batman7 Jun 05, 2008
    keeps telling me check manuel for troubleshooting. wont read disc
  • 3 Answers
If you have game cube games you may want to try them as well. If it plays the game cube games but not the wii games it sounds like the sensor inside is bad and you will need to contact nintendo so they can fix the sensor.
Posted on Jun 02, 2008
Console makes clicking noise when disc is inserted and disc will not start? Screen says error has occurred and to consult manual. It happens with every disc I insert
I Had the same thing happen! It has to do with the retention clip. Here you go:
How to Fix Wii Disk Read Errors Game Front
After you fix it, don't leave game disks overnight or in for extended periods of time as that pulls the clip down.
Sep 13, 2014 | Nintendo Wii Console
Wii Disk Error
Unable to Read the Disc" Error, or Disc Not Recognized (Will Not Play Game Discs) Situation:
  • The Wii console will not play game discs (disc is not recognized)
  • System displays either error message "Unable to read disc" or "Disc could not be read"
Important!
  • If this problem happens very infrequently, it is normal and does not indicate a problem. A Wii Lens Cleaning Kit can be purchased to help keep the lens clean and prevent the situation from worsening over time.
  • Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
  • The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
  • An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • Verify that the console is placed correctly.
    • If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
    • If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
  • Verify that the disc is being inserted properly.
    • If the console is placed horizontally, the disc label will face upwards.
    • If the console is placed vertically, the disc label will face to the right.
  • Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
    • If the disc is dirty, try cleaning the game disc. (How to)
    • If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
  • Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Situation Not Resolved:
How many games does this occur with?
Mar 17, 2012 | Nintendo Wii Console
Put mario cart in and go through until it says error occured eject and turn off etc but it will not turn off
This error occurs if you have a problem with the disc. This normally happens if the wii console cannot read or recognize the game disc and freezing usually occurs after the error. You need to restart the wii console if this happens. Also check the disc for any visible damage and try cleaning if dirt is present. If this happens on all or majority of your games, there could be a problem with your wii's disc drive, but if it only occurs on a specific game then the problem is with the disc itself. Good luck!
Jul 21, 2011 | Nintendo Wii Console
My wii console turns on and when I place the wii fit or wii sports CD in the console, everything looks fine. I then get the menu on the screen. But when I press the wii fit -nothing happens. When I place...
if by doesnt begin you do you mean doesnt read disc or fails to start game because if its doesnt read disc look for scratches on the disc if its doesnt initialize then it could be the disc drive itself is bad then go to http://www.nintendo.com/consumer/systems/wii/en_na/index.jsp
Jan 16, 2010 | Nintendo Wii Console
Do not read any disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc.. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 04, 2009 | Nintendo Wii Console
One Wii won't read discs the other won't turn on!
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 26, 2008 | Nintendo Wii Console
The Wii will not read the disc
"Unable to read disc" error happened today for the first time on my Wii. I positioned it horizontally and tapped on the top while it was reading a disc and it started the game. This temporary solution might bring you immediate, but probably not long lasting satisfaction.
Sep 12, 2008 | Nintendo Wii Console
Rock Band / All Games "Unable to Read Disk"
Aug 10, 2008 | Nintendo Wii Console
Error occured while loading disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Aug 09, 2008 | Nintendo Wii Console
Error reading disc turn power off
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the Exisitng Disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
May 21, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
164 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
