Question about Car Audio & Video
Radio code for truck casis no WDB9342332L081976
  • bdxsport Oct 09, 2010
    i dont know a radio model only mercedes benz truckline
    im using this truck 2546 casis number WDB9342332L081976
    but dont have a radio code number
    President:
  • 2,777 Answers
What is the make / model of the radio? If it is a stock radio you need to have a dealership give you the code, it is tied to the vehicle and for security purposes they can't just give them out. They will give it to you / unlock it for free though in person.
Thanks
Tim
Posted on Oct 09, 2010
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    And this is the radio that came factory installed with the truck correct? The same thing still applies, it needs to be done by a dealer that is authorized to work on those models. It is an anti-theft control mechanism.
    Tim
  • Tim Grayson
    I understand, but noone here can just give you the code number, it has to be done in person by an authorized place.
    Thanks
    Tim
El carro enciende y trabaja bien en un principio despues de un tiempo se apaga el motor como que no llegara gasolina al motor, y no enciende mas hasta pasado un buen tiempo cuando se enfria el motor...
Hi!!
Por el a?o del vehiculo, casi puedo apostar que es la bomba de la gasolina. Cuando las bombas empiezan a fallar, trabajan por un rato, despues se calientan y dejan de trabajar, al poco tiempo, ya no trabajan para nada. Casi todas las tiendas de auto partes grandes como AutoZone y Checkers prestan herramienta. Consigue un Fuel Pump Pressure tester para que chequees la bomba de la gasolina. Ahi mismo te dicen cual es la presion que debe de tener. La presion se chequea abriendo la llave pero sin arrancar el vehiculo. Aqui esta un diagrama de como se connecta el probador.
Buena Suerte!!
Mar 16, 2011 | 1991 Honda Civic
My casie ce-3700 is showing error code 08, how can i resolve this problem?
You have logged yourself off. Try pressing 1 then CLK#
If anyone needs a Casio CE-3700 manual, C-tech has them here: http://the-checkout-tech.com/manuals/cashregisters/casio1.php
Dec 14, 2010 | Casio Parts Cash Register PC Desktop
Tengo problemas con los frenos, se me enciende la luz indicativa del ABS, y el problema es que cuando freno, al momento en que casi se detiene el vehiculo jala hacia la derecha, como si solo frenara ese la...
evidentemente la luz se enciende por un fallo, revise que el caliper o compensador del lado derecho no este muy ajustado y tambien purgue el sistema por posibilidad de aire en el sistema
Jun 08, 2017 | 1993 Toyota Previa
La temperatura normal de un motor mazda tribute 2001
la tempeeratura puede ser de 195 a 205f la aguja casi lllega a la mitad
Oct 05, 2010 | 2001 Mazda Tribute
Transmicion
el aceite de la transmision es rosado y la pieza para checarlo se parece al del aceite del motor. dependiendo si es traccion trasera o delantera. si es trasera estara asta atras del motor a cual quier lado. si es frontal tendria que estar casi en el medio del compartimiento del motor casi a un lado de el bloque del motor.
Feb 21, 2010 | 1993 Honda Accord
Desbloquer
Primero trata de presionar el boton del RESET con un lapiz,por lo regular casi todos los radios tienen este boton un poco escondido que parece un puntito.
Si no hace ninguna diferencia,entonce el problema va a estar en el circuto de salida que se tiene que reemplazar.si tu no tienes experiencia en desoldar y soldar,te recomiendo que lo lleves a algun taller.
Si tienes alguna pregunta mi email es electroxpress@peoplepc.com
Gracias y buena suerte
Jul 24, 2008 | Car Audio & Video
Parts Wanted (ECU 5K)
You should contact Mazda Authorized Service Center for this.
Jul 12, 2008 | 1994 Mazda 323
Repair seat stiching
su revolucin inicial es casi 1 lo siento acelerado y cada sierto tienpo samaquea toda la carroseria me da 14 millasa por galon
Jul 01, 2008 | 2003 Chevrolet Corvette
Looking for part number
do not interchange
May 19, 2008 | 1994 Mazda 323
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
