Question about Brown Stove Works TM210 Gas Kitchen Range
Brown TM210-4 kitchen range... how do i switch from LP Gas to Nat. Gas on this model? Is it just a regulator adjustment? or do i have to change the orifices as well?
  • 494 Answers
Both. If this is a sealed top range, then you will have to change out the orifices and flip the cap on the regulator. If this is an open top style range (the top lifts up around the burners) then the orifices need to be adjusted and the regulator cap flipped. The oven/broiler orifices will also need to be changed or adjusted, depending on which kind they have. Some older models also require converting the oven thermostat from LP to natural gas (and vice versa) by turning the screw to the correct marked setting. If you have your owner's manual, it explains the conversion in it. If not we may be able to find it online for you to download. Douglas
Posted on Oct 09, 2010
Why is it no matter which way I adjust the oven's spud orifice, the burner flame stays large, yellow and sooty even after adjusting the air shutter?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
Why does the oven burner seem to be getting too much gas?
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Maxitrol cv47clr
Usually to convert the regulator you remove the knob in the center of the regulator by pushing it in and turning it. Then remove knob and flip it over and re install it there should be Nat and L.P. markings on the knob. Hope this helps.
Dec 15, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Natural gas to lp
I have a. caloric mod rls340 with regulator. what is the procedure to switch it to lp from nat gas??
Dec 30, 2008 | Maytag MGR5770 Gas Kitchen Range
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Converting from lp gas to natural gas
just the orifices will do, the bake and broilerahve an adjustable hood thatwill need to be tightened down as well as an adjustment made to the regulator(needs brass nut flipped from nat. to lp.)
Mar 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Brown Stove Works TM210 Gas Kitchen Range Logo
179 people viewed this question
Top Brown Stove Works Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Are you a Brown Stove Works Kitchen Range Expert? Answer questions, earn points and help others
