Question about Canon LASER SHOT LBP-5000 Printer
Our Canon LBP5000 has a calibration problem which results in the separate colours of an image printing slightly apart giving a ghosting or shadowing effect. This is not consistent with every print. The toners are all quite new - any ideas how to resolve this?
    Guru:
  • Canon Master
  • 452 Answers
Hi; the Video controller is not working properly the solution is : change the video controller (video controller wich contain the USB port )
Posted on Oct 17, 2010
  • reginakorf Jan 03, 2011
    Hello, we're from Holland. Your answer is that we should change the video controller (video controller wich contain the USB port. What do you mean exactly by this. Where can we find the videocontroller? On the printer lbp5000 ore on the PC? Can you explaine it at bit more for us?
    We have the exactly the same Problem with the shadow or a ghosting. But only by the blue/cyan color. Whe have already changed the cartridge. Please help us.
    Kind regards, Regina
  • polytek Jan 03, 2011
    hi, you are welcome, the vdo controller is located on the printer it's an electronic card wich control the video signal generated by the usb port. if you have a problem of ghosting first try to execute the calibration process from the canon software from your pc, after finshing the calibrabration send a job to the printer, if still no change you have to replace the video controller, buy a new one from canon.
2 Suggested Answers
  • 452 Answers
SOURCE: Our Canon LBP5000 has a calibration problem which
Hi; this problem is caused by the video controller to resolve this problem change the video controller
Why is there ghost printing/shadows on my xerox workcentre 7335?
Suresh,
You don't say if the ghost is a particular colour, by ghost I suspect you mean similar to a drop shadow.
Firstly run off an internal test print, one of each colour if the grid lines are fine and showing no signs of shadow then your problem is not an internal problem. Don't send a C,M,Y,K test print from your computer, you can't eliminate colours that way.
If you can pin the problem down to one colour it could be a particular drum unit. Investigate from there.
Good Luck.
May 03, 2015 | Xerox Workcentre 7335 All-in-one Laser...
My canon irc 3200n is printing shaken images
Difficult to say without seeing the quality of the prints but sounds like a calibration issue. By shaken to you mean that colours have fallen out of line and are leaving outlines on your prints? Possibly giving it a 3D-like effect?
If so I would recommend running a few calibration/alignment cycles from the printer or printer software to bring all the colours back into line.
Aug 07, 2013 | Brother DCP 115C All-In-One InkJet Printer
My HP Photosmart C4280 doesn't give correct colours when scanning
You can usually calibrate your printer. When you first get your printer you may have to run through tests. One of them is where you print out a sheet with multiple colours on it and you then scan it to calibrate the scanner.Scanning will rarely give a perfect representation of the actual photo or image but if you do calibrate it may solve your problems.
Jan 24, 2012 | HP Photosmart C4280 All-in-One InkJet...
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
My lbp5000 prints the colour image seperate from the black image, although it's supposed to be one image
The printer is need to Calibrate. Calibrate the printer from the menu in the taskbar down/right to the clock. Calibrate several times until printing is good.
Jan 08, 2011 | Canon LBP5000
Canon LBP5000. The printer has stated to print a shadow image of the darker parts of the print. Not always from the start but after some prints. The shasow image can also be from the previous print. It is...
Had the same problem with LBP5000. Used the Cleaning Utility(Options/Cleaning) in the printer software, had to run it several times, the shadow did not go away the first time. Looks all right now.
Hope this helps.
Thor.
Nov 08, 2010 | Office Equipment & Supplies
Canon LBP5000 laser colour printer. Problem: 'Out of Register Colors Correction has not been performed. Perform calibration again'. I have carried out this instruction so many times, the error keeps...
Had the same problem a while ago.
In my case it was simply that the plastic tab had come away from the plastic strip you're supposed to pull out from from the cartridge before installing. Found the end of the plastic strip and pulled it out and this sorted the error.
An additional problem we had was alignment of the colours when printed. Magenta and black were misaligned by about 0.5mm after changing a cartridge. This was cured (after much frustrated cleaning/calibration) by switching the printer power off and on (couple of minutes to cool down).
Hope this helps.
AJ
Nov 16, 2008 | Office Equipment & Supplies
Ghost image when printing in colour.
There must be a calibration option in the printer's menus, dig around, might be in a maintenance or service menu. Could also be found in a program on your computer sometimes.
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Canon LASER SHOT LBP-5000 Printer Logo
1,755 people viewed this question
old marine
old marine
