Question about Refrigerators
I REPLACED the highout put board on the back off the ref..... now the ref.... will not start up. the freezer control showsPEO THE REF.. CONTROL SHOWS 000. AND MODEL # AND SEARIAL TAG IS MISSING SO HOW DO I GO ABOUT PUTING THE CODE IN AND HOW DO I DO THAT.
    Master:
  • 497 Answers
Can you please tell me who the Manufacturer is as well as describing the refridgerator as best and detailed as possible? Thank You
Posted on Oct 09, 2010
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
It no longer gets cold or freezes.Just started doing this. It is now defrosting,water is dripping on the floor from the freezer door.I turned both ref.& freezer controls as low as it will go. This did not...
Your refrigerator has a control board located on the back behind a panel. Unplug and remove cover to examine the board. It is very possible the board is defective and will nee replaced. The board part number is WR55X10656 and if you need further help let me know, Thanks, Sea Breeze
Mar 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GDS20SBSBSS FREEZER DRAWER WON'T OPEN
ice will most likely form again.you have a defrost problem.most likely it is your defrost heater.their are a few things that control your defrost cycle.defrost timer,thermostat and defrost heater.most of your newer ref. will also have a control board on the back of ref. or under ref in a usually grey box.but check your heaters first.you will need to take the back panel off in freezer.you will see heater at the bottom of coils.if you have a set of meters you can check for continuity to heater.also your drain below heater sounds clogged.i usually steam out drain but you can use hot water.water should go down drainwhen unclogged.that will prevent the drawer from sticking.
Jan 26, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Ice will not eject from door.
their is a control board on back of the ref. this board controls most of the components to ref.i have seen alot of the ge ref. with same problem.replacing control board should solve problem but the board is very pricey.is ice coming thru door worth a couple hundred dollars?
Jan 10, 2009 | GE Profile PSI23NCR Side by Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer gets cold, Refrigerator Hot
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You can't see the door but, you should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system which consist of the defrost timer, heater, and thermo disc.
Also, If you replaced the evaporator fan then you got a good look at the cooling coils. Look at these coils while it is running. There should be a light coat of frost on all the coils. If this frost line is only 3/4 or 1/2 or any amount less than full coverage of the coils then the system has a coolant leak.
Directly under these coils is the drain pan and drain hole in the middle. This area should be clear of any ice or debris.
Dec 25, 2008 | Kenmore Refrigerators
No cold air coming into the fridg
check your control setting. You should be able to feel air coming through the channel on the Ref side.
This is a failure of the defrost system.
You can melt this ice manually for a temp fix but the defrost system needs to be checked. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can without anything thawing then put it back in, turn it on and you will be good for a couple of days.
Nov 21, 2008 | Jenn-Air JCD2389G Side by Side...
Warm refrigerator
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can before anything starts to thaw. Put everything back in, turn it on and this should last a couple of days.
Oct 28, 2008 | Jenn-Air JCD2389G Side by Side...
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
