I to want replace a regular duplex outlet with a TM818-WCC6 and want just the outlet switched. How do I wire it?
The Pass and Seymour plug-switch combo has 3 screws
There is a dark screw on one side .... the black Hot wire from breaker box connects here
There are silver and brass colored screws on other side of device
The white Neutral from breaker box connects to silver screw connects here >>> this will give power to your receptacle
The black wire going to Load (light, fan, motor that you want switch to control) connects to brass colored screw ... the switch controls power to Load
How to test for black Hot
Remove devices and separate wires
Turn on power
Test each wire to bare copper wire
Tester lights up on black Hot wire
How to test for white Neutral
Test black Hot to each white wire
Tester lights up on Neutral
