Question about Garden
Generato only able to run 2 saws at a time not generating enough power
    Problem Solver:
  • 8 Answers
Your generator is too small. if you have a unit that only has a duplex outlet or you can carry it with one hand, it might be time to upgrade. To find out the wattage you will need look at the data plate on the saws, there will be a number next to the word AMP once you have this from both saws add them together. With this amperage we will make a small calculation using watts law which states Watts divided by voltage equals amps. Also most generators are designed to run a constant current unlike the erradic draw that would be created by only one saw. When you figure out your load demand, add 15% to it as allowance for the surge in power. In cases of chain-binding or really hard wood, the saw requires much more amperage.
Posted on Oct 09, 2010
No cold start
Well first of if it cranks slow, make sure the correct battery voltage is being applied. IS the pre-heat function working? If that is not it won't start when cold. Also check oil viscosity is correct. If the pre-heat is working make sure glow plugs are getting warm on each cylinder.
Jan 24, 2014 | Onan Cummins 10.0 HDKCA/11506 RV QD 10000...
Starts and stops
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Dec 11, 2013 | Onan Cummins 12.5 HDKCB/11506 RV QD 12500...
Onan quiet diesel 6000 won't crank clicks
Check battery voltage, starter solenoid, then starter motor
Mar 31, 2013 | Onan Cummins 12.5 HDKCB/11506 RV QD 12500...
HOW CAN I OPERATE SHARP AR 5520 COPIER WITH 30 KVA GENERATO POWER SUPPLY?
Hi, this power is not stable and enough. You need a big generator to work with this machine since it needs more power and you will agree with me that once you connected, the sound of the generator changed.
Nov 28, 2011 | Sharp AR-5320 Black and White Copier
I have a 1984 winnebago motrhome with a 6500nh rv onan generato runs getting power on the line but none in the motorhome
Hooked in to motorhome via automatic switchover, or does the power plug of motorhome have to be plugged in to receptacle at or near generator?
Mar 15, 2010 | Watts Onan Portable Generator - 5000 ,...
BRAND NEW GENERATOR NO POWER
tim n tennessee ...if the gen. runs fine and generates no power...:
1- check brushes.
2- check wireing.
3- check AVR card.
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 17, 2009 | Honda 6370C - Parallel Power Kit For ...
Power needed to operate?
No. During operation the pole saw will draw 960w. With an extension cord you will have some loses that will kick you to the edge of it's operating limit.
The biggest problem is when you start the pole saw it will draw 2 to 3 times it's running current, putting it at 1920w.
Sorry but no.
Mar 31, 2009 | Remington Electric Pole Saw
Long storeage of troybuilt gen
i have had my generator for 6 years. i use fuel stabilizer and do as you did in shutting it down. I do not drain my fuel but it doesnt hurt. I would question putting anything in the engine that could in time cause problems. I use synthetic oil, this should coat all internal parts well enough to not need extra oil. I do start the engine a few times a year and let it run 5 mins. or so. I live in SW La so having a generator that doesnt work during hurricane season is not a good idea. The steps you are taking should keep your engine fine. It is a good idea to run it and use the power every now and then. This keeps the magnets in the generator in good shape.
Oct 12, 2008 | Electrical Supplies
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
