Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
I pluuged in & it tripped the breaker. I pulled the oil plug (grren palstic) & looks like very little oil. Stick was oily but not dripping off at all. I notices there is no fill mark on the oil stick. The compressor humms when plugged in but wont run. Any thoughts? Regards Brett
    President:
  • 1,033 Answers
Are you hooking within 5ft of the outlet? If you are running a cord, then the cord can't keep the amp rating needed to run the compressor. I have one that does the exact thing. Try plugging it in close.
Posted on Oct 09, 2010
Raven 4000 generator won't start. It has new gas, oil that came with it... It isn't sparking. Hurricane coming, please help!
Your dip stick should have level marks to tell you when its up to where it is suppose to be and when it is low. if you over fill it won't start . Did you check the level before you added any oil. some times they put oil in at the factory as well as give you an extra can of oil. Pull your spark plug out and see if its oily or if it has gasoline on it. If its oily you may have to take some oil out. If the plug is dry then maybe you have to choke it more if you have a primer bulb then you can try pushing it more. Some engines say to push bulb only three times but quite often takes more.
Oct 07, 2016 | Cars & Trucks
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
Duo therm mod. 57915 air conditioner seems to work good , runs for 4-5 minutes then kicks breaker , was kicking 30 amp breaker at camp ground , i've been working on connections to make sure its...
Unit may pull as much as 17-18amps when compressor starts up, but level out to 12-15 amps when up and running. Keeping in mind that is all relative to proper 120v incoming voltage, heavy enough wire to run the application etc. If your AC unit needs cleaning , it may draw an extra amp or 2 . With that said, when your at the park, first thing I'd question is their incoming voltage to RV, and try running fridge etc and anything else on propane if possible. The AC alone should not cause 30amp at source breaker to trip, before 15 0r 20 amp breaker in RV that is connected to AC trips. If it doesn't trip your breaker at home, and all is connected same at park, then I certainly would suspect bad breaker or voltage/wiring at park is the cause. P.S. I noticed you said you have 12 gauge wire (rated at 20 amps) connected to a 20amp breaker at panel, but RV is plugged in to a 15amp receptacle, I will assume with a 15 amp adapter from 30 amp plug. Do you see any hazard regarding 15 amp rating on receptacle? ( just a little advice.)
Aug 15, 2011 | Dometic Rooftop RV Air Conditioner
My dryer runs and drys but after a little while it will trip the breaker in the electrical panel. Anyone have a clue? It's a GE mod.# DLLLR23EG1WW. Thanks in advance for any help. Tom
Hello, W/D here.
When a machine is operating properly, but then trips the breaker, the breaker itself seems to be suspect. Breakers wear over time, and can become "weak". Also, amps on a breaker are time weighted. The more amps that you pull, the less time it takes for the breaker to trip. This is also true with a weak breaker. Check the amps that you should pull with your dryer, and check the breaker. If the breaker is the correct size, try replacing it. You should be on a 30 amp breaker/circuit.
Here are some useful links for your dryer:
Owner's manual http://www.managemylife.com/mmh/owner_manuals/6276/GE-Residential-Dryer-L0707113?brand_name_search=DLLLR23EG1WW+GE Installation guide accessible from same link.
Parts manual http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DLLLR23EG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DLLLR23EG1WW
Best regards, --W/D--
Apr 07, 2011 | Dryers
All the oil gone after a 20 mile round trip - has it burnt off or did it leak - that's the question - it's a 1.4 y reg golf - petrol...
I can't imagine that your car is "burning" all that oil in 20 miles. To be sure, remove the spark plugs and look for a lot of ash or really black/oily plugs. I would say more than likely you have an oil leak. Check under your car for a lot of oil streaking. At that rate it should be everywhere underneath.
Dec 07, 2010 | Volkswagen Golf Cars & Trucks
2006 Chrysler T&C transmission leak
a bolt most likely vibrated loose and is letting transmission fluid leak out. try finding it and tighten it back up. or your dipstick housing is loose and the pressure is allowing fluid to leak out.
Jun 02, 2009 | 2006 Chrysler Town & Country
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
122 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
