Question about Coby MP-C7085 MP3 Player
Wont tuurn on
My coby will only turn on if i plug it into the computer....i have music on it and everything but it wont turn on if it is not plugged into the coomputer
    Problem Solver:
  • 12 Answers
Reset your unit
press the reset with a toothpick in the bottom right in the back.
wait a bit then try to turn it on.
Posted on Jun 01, 2008
My M-610 MP3 keeps saying its unplugged even when it's not?
Here are instructions for a solution to your Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 10, 2010 | Coby MP-610 MP3 Player
My coby mp 610 turned of apparently while i was listening to it but the screen is still bright and it wont do anything now. How do i fix that?
Here are instructions for a solution to your Coby 610 MP3 player acting up.
Here are the steps:
I hope that helps.
Jan 03, 2010 | Coby MP-610 MP3 Player
My coby mp 610 wont play all the music i have on it.
I use a different MP3 player, but I noticed that mine wouldn't play .AAC files, only .MP3 files. I upgraded the firmware of mine and then it played everything. I noticed there is a new firmware upgrade for the COBY 610, so that might be of help to you.
Here are the steps:
  9. After the firmware update is complete, you will receive a checkmark in the Firmware box.
I hope that helps.
Dec 28, 2009 | Coby MP-610 MP3 Player
Every time i try to turn mp3 on the screen only says coby the main screen wont show the music icon or let me do anything else
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again.You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Here are the steps:
I hope that helps.
Dec 27, 2009 | Coby MP-610 MP3 Player
I plug my coby mp3 n the computer can't read it
Here are instructions for a solution to your frozen Coby 610 problem. This works even though the MP3 player is having problems talking to your computer. They should communicate fine after this update.
Here are the steps:
I hope that helps.
Dec 25, 2009 | Coby MP-610 MP3 Player
I synced music from windows media player to my coby MP-C781 MP3 player and now it wont power on. And I've tried everything
what I would do is plug it back to the computer and if that works what you should do is go to the manufactures website and download new firmware for your player and reflash the player and try draging a dropping the music instead of using windows media player. this is how you can drag and drop:
first off find where your music is stored and open up that window then open up a window with you mp3 player in it and drag and drop the music into the window with your mp3 player
Sep 29, 2009 | Coby MP-C781 MP3 Player
Coby mp305 usb stick w/ fm radio display says file system error & wont allow me to access menu to use fm radio or anything. cobys website has proven to be worthless. any suggestions would be appreciated....
I just fixed my co workers device. Plug in the device into the PC after it plugged into the pc, the pc will detect the device after the device is detected. In My Computer, double click on the coby device, it will bring you to the the storage device, its also named coby something. right click on it and format. You'll lose all your data but the file system error message will be fixed. Reload music and you're back and running.
May 02, 2009 | Coby MP300 MP3 Player
Coby 2g mp3 wont charge
go to.
setup
power
sleep
and select off
I you hope to have helped
Dec 28, 2008 | Coby MP-C7085 MP3 Player
Frozen
I JUST ENDED UP RESETING IT AND EVERYTHING WAS THE SAME, MUSIC WISE.
Nov 07, 2008 | Coby MP-C7085 MP3 Player
Coby MP-C7085 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
