Question about Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw
My chain is loose - Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw
  • 520 Answers
There is an adjustment either on the same side as the bar or possible in the front near the bar. if you dont know how to adjust the chain properly then you really need to look through the manual. if you dont do it right you can cause more damage.
Posted on Oct 09, 2010
How loose can the valve timing chains be and still run?
There is a tensioner and being loose is not as bad as wear, you might notice some backfire noise when the wear gets excessive.
Mar 24, 2015 | Cars & Trucks
My bike chain always become loose ??
Both, chains and sprockets have "pitch" if they are not the same pitch the chain will become tight then loose breaking the bearings and destroying the chain
Apr 01, 2014 | Regina Chain 520 ZRD Chain and Sprocket...
Chain comes loose ms 391
Check the chain tension as you cut. The chain will stretch as it warms up. Be sure the side bolts that hold the bar are snug. Lift the bar upward when you are adjusting the chain and while you tighten the side bolts. Never cut with a loose chain.
Oct 24, 2013 | Stihl Garden
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
Chain comes off mcculloch electramac em250 chain saw
Your chain is too loose or it is worn out. Adjust the tension on the chain. The chain should not hang away from the bar but should be loose enough that you can pull it away from the bar with not much effort. Adjust the tension until it is set correctly.
Apr 25, 2010 | Plumbing
Chain keeps coming off Poulan 2150 woodsman gas chainsaw> Common causes?
The most likely cause is a loose chain.
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
HTH
Lou
Dec 16, 2009 | Garden
Loose chain
it sure can happen. You can also take a link out of the chain to shorten it also, best thing buy a new chain.
Dec 06, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
I have a poulan pro 260 chainsaw and just replaced the bar and chain. Tighten chain and brake nuts and after a few seconds of cutting the bar is shaking and the chain is loose. Switched back to the old bar...
check the cog that the chain runs on, the one on the back of the centrifugal clutch they are supposed to be changed when you change the bar ((i dont bother until iget symptoms like yours or the chain starts to get tight and loose tight and loose)
Jul 28, 2009 | Garden
Loose chain
I had a few chain driven polaris atv's they tension when weight is on the quad, the rear arm pivots and applies tension to the chain , other then that there should just be guides for the chain. If the chain is still loose with operator weight the chain may have play in the pins and need replaced.
May 05, 2009 | Polaris ATV
Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
