Wiring diagram for mc64c mastercool - Heating & Cooling
4 Suggested Answers
SOURCE: Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
Posted on Jun 06, 2009
  • 6 Answers
SOURCE: I need a wiring diagram for a mastercool
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Posted on Feb 14, 2010
  • 587 Answers
SOURCE: high speed does not work but low speed does
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
Posted on May 30, 2010
Testimonial: "great answer - I'll check it today"
Our mastercool thermostat does not have any power going to it whatsoever. It is only a 3 year old unit and we have checked all the fuses and wiring which all seem to be fine. We even changed the main...
If it's a 24 volt thermostat, the inline transformer has failed and needs to be replaced. Some are 18 volts, and they require a transformer too. I suspect that's the problem, since the T-Stat is not getting power.
Hope this helps you solve the problem. Please let me know. Thanks.
May 06, 2011 | Mastercool 67680 Evaporative Cooler Air...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
Wiring issue on mastercool 5 CFM 2 stage pump
Black wire is " hot" White wire is: neutral Green wire is ground
This is for 110v AC
Apr 25, 2010 | Mastercool (MSC90066) 5 CFM Economy Series...
Need wiring diagram for model MC 63e
It should be on the inside of the service panel.
Apr 18, 2010 | Mastercool 67680 Evaporative Cooler Air...
Fuses blowing, wiring is good.how can I test the transformer?
disconnect the motor wiring. Should be a plug that you can locate and pull apart. now try applying power. Fuse may not blow. Also disconnect pump.
Oct 25, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
116 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
