Question about Dell Latitude D800 Notebook
Blue Screen, Frozen Boot, NMI Parity Check
I've got a Dell Latitude D800 I've had for a few years. It's got 1GB of DDR RAM (2 512 sticks), and I haven't made any hardware changes since I purchased. Lately I've been getting the dreaded blue screen. I've been able to hard reboot and it works fine. I've also got a problem with it recognizing my DVD/CD Drive when it's in the docking station. Most recently, I went to boot up my pc and it froze just after the XP logo screen - prior to the "login as" screen... it pauses on the screen that says "waiting". If I let it run for about 30 minutes it will sometimes pull up the desktop, but not load my system tray or give me access to any desktop icons - it just remains frozen. Most times however I get the "Hardware failure, NMI Parity Check - Memory Parity Failure" message...
I've tried pulling memory sticks one by one to see if that was a problem, but I get the same issue.
I'm able to boot in safemode only.
Any ideas what to check next?
  • Dell Master
  • 13,433 Answers
Test both your memory modules with memtest
http://www.memtest.org/
It may be a windows problem that might go away with a fresh windows installation. As you said it takes very long to start up that might point to a harddrive problem.
you can read about harddrive testing here
http://pcsupport.about.com/od/toolsofthetrade/f/testharddrive.htm
Posted on May 30, 2008
Bij doorstarten moet ik steeds f1 indrukken en bij het afsluiten krijg ik een blauw scherm met de tekst Hardware malfuction call your hardware vendor for support NMI:parity check/memery parity...
NMI parity error (Non-maskable Interrupt) is generally a motherboard or a RAM issue.
You can try flashing the BIOS to A04 (You'll need to copy the flash executable to a bootable CD or bootable USB drive to run the flash.
Try individual or different RAM modules
if all those do not resolve, issue is most likely the motherboard.
Jul 07, 2011 | Dell Dimension 3100 PC Desktop
I'm getting a blue screen on my Dell Optiplex 360 and an error report saying; "NMI:Parity Check/Memory parity error.I've cleaned the computer,scanned the hard disc,but it still pops...
It sounds like a RAM issue. Try downloading memtest 86+ (http://www.memtest.org/) that'll give you an idea as to whether it's the memory or not. If it is, try swapping them out (take out one, take out another, swap ports, etc) to narrow down if it's one or both.
Jun 13, 2011 | Dell OptiPlex 360 Desktop Computer
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
Jul 31, 2010 | Dell Dimension 3000 PC Desktop
NMI:parity check /memory parity error
In my experience, you get a memory parity error when one of your memory sticks has gone bad.
I don't know how many sticks of memory you have or what size they are, but you can try removing one and see if the error goes away. If not, remove another and try again.
You're probably looking at buying some new memory. If so, use the opportunity to increase your memory within the limits of your operating system.
Win XP, 32 bit, will see up to about 3.2MB of RAM
64 bit can see over that up to about 8MB
Jun 16, 2009 | Digital Audio Labs CardDeluxe Sound Card
Parity error :only when im playing games, after playing a game 20 minutes (10 if it has good graphics) the computer screen goes blue and it says "Call your hardware vendor for support NMI: Parity check/...
increase ur virtual memory then for high resolution game u should install a graphics card , nvidia graphics card is the good quality card . After doing that plz check
Jun 01, 2009 | IBM Lenovo ThinkPad R60 Notebook
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Dell Latitude D600 - RAM not recognized
One of the DIMMS might be incompatible or faulry.
Put one DIMM in at a time to determine which is not working.
If they both work separately then it appears they are incompatible together. Try to get the DIMMs from the same manufacturer, with the same specs.
Mar 08, 2009 | Dell Latitude D600 Notebook
Dell Latitude D800 Boot Problem
Did the diagnostics pass the RAM and the hard drive.
You should check the BIOS settings to see if the hard disk is detected, if possible reset the BIOS back to the default settings and see if the computer boots up.
If not :-
Then it appears that the operating system is either corrupted or system files were deleted or infected with viruses.
Your only option is to do a operating system repair or a complete new install of Windows.
I recommend you do a new install.
Nov 22, 2008 | Dell Latitude D600 Notebook
Hardware malfunction
HARDWARE MALFUNCTION CALL YOUR HARDWARE VENDOR FOR SUPPORT NMI : PARITY CHECK / MEMORY PARITY ERROR THE SYSTEM HAS HALTED
Dec 07, 2007 | Dell Inspiron 6400 Notebook
Dell Latitude D800 Notebook Logo
539 people viewed this question
Alun Cox
