Question about Acer AOpen AX 6B Plus (91.87810.321) Motherboard
No signal input
Hi, i have a acer desktop computer bought from currys, one of the cheaper ones with integrated graphics, over the past couple of weeks it as, on a couple of occasions when turned on, stayed on the acer screen on my moniter.... before loading windows. it has got to the point now where the acer logo will not dissapear from the moniter, and consiquently windows will not load. the computer it self sounds fine when i switch it on, no beeps, smoke etc, i have tried using the f12 button, well all of the buttons but nothing happens. It got to the point yesterday where i almost stripped my other pc down trying different components ie, hard drive , ram chips, graphics card, but nothing happened still stayed on the acer screen, i have also tried unplugging everything form the motherboard except the fans to see if it would show an error but still just the acer screen came on with a messaege no signal input before the acer logo stayed on. please can you help me, many thanks paul
  • 3 more comments
  • drummerpaul May 31, 2008
    hi, thankyou for your time and help! the coolant seems to be very minimal ( the grey paste at the back of the fan on the back of the processor) does this mean that the processor is possibly fried. shall i apply more paste? thankyou
    thankyou, I will try and source some coolant first then! many thanks
  • drummerpaul Jun 01, 2008
    HI, I have tried more coolant but it didnt seem to work, i have also tried resetting the c,mos by removing the jumper and reinserting, still just have the same acer screen.
    thankyou for getting back to me! today i tried removing the jumper (c,mos)from terninal 1 and 2 and installed on two and three then back on one and two while switched off, still nothing, i also tried installing the backup disk, the disk drive was working fine, but still nothing, i removed the ram chip and then switched on the pc, the pc started beeping once every 3 or 4 seconds, is this normal with no ram chip installed? thanks
  • drummerpaul Jun 02, 2008
    HI, THANKS! is it possible that it could be that windows are corrupt?
    Scholar:
  • 187 Answers
Check the coolant between the CPU and the cooler to ensure it's not simply over heated.
Posted on May 31, 2008
  • 3 more comments
  • Steven Burn
    Steven Burn May 31, 2008
    I'd recommend cleaning whats there with a paper towel to get rid of it, then replacing it with fresh coolant.
    It's possible that the CPU is fried, but I wouldn't say with any certainty until the coolant has been replaced and the fans etc, checked.
  • Steven Burn
    No problem.
    You can pick up the coolant at most PC stores for a couple of quid.
  • Steven Burn
    Steven Burn Jun 01, 2008
    In that case, and unfortunately, it's only been narrowed down to one of two things;
    1. A faulty motherboard
    2. A faulty drive/RAM
    To check the drives, disconnect the power and IDE cables from the CD drive(s), and try booting. Then further, try unplugging the hard drive (with the CD drives plugged back in).
    If the problem persists after checking the drives, remove the RAM chip (if you've got more than one, only remove one chip at a time to rule out a faulty RAM module).
  • Steven Burn
    Thats normal with no RAM chip, yes. Short of a secondary RAM chip and assuming all drives have been ruled out, I'm 95% certain the problem is with your board and would subsequently recommend replacing it.
  • Steven Burn
    Steven Burn Jun 02, 2008
    It's very unlikely (specifically because you mentioned it's not getting further than the initial Acer loading screen). However, computers will be computers, so nothing is ever definitive (if you'd like to try a repair or re-install of Windows to rule that out, the more the better (tis always best to be thorough ;o) )).
My Acer m1201 desktop computer will not come on.After turning on , then switch monitor off and on , It says ACER, then "no signal" .How can I fix it?
Acer monitors all display the ACER logo when you turn them on. There are one of three most likely issues with the system.
  1. If the monitor has multiple input jacks (VGA/DVI), check to be sure that the monitor is selecting the input that you have the computer connected to. One of the control buttons on the monitor should select input source.
  2. If #1 is not the problem, the monitor itself may be faulty. The input jack may not be working. Test the system with another monitor if possible.
  3. If another monitor doesn't work either, then you have a problem with the on-board graphics adapter for the computer. You will either need to replace the computer, or if possible, install a graphics card into the machine to take over for the failed portion of the motherboard.
Dec 08, 2015 | Acer Computers & Internet
Asrock alivenf6g vsta
try a differant monitor if not working then its the board get a new one.
Oct 09, 2013 | Computers & Internet
Black screen during startup Acer Aspire L310
Has your monitor worked for it in the past? This may be a stupid question, have you also tried to use your monitor with another computer?
It's possible your graphics controller is out, have you checked the cables insides to see if any wires are bent? Or have you tried to use another cable for the monitor to tower connection?
If you have done all of the above and the monitor works with another computer, it's possible your GPU is out :(
If your GPU is out, you can buy a new one in it's place and it will plug into a PCI slot, chances are your graphics card is integrated.
Do you get any beep codes on the computer? Another odd chance could be the computer itself is actually dead, even if a computer is dead a motherboard can still be active since electricity can still flow through it.
I hope this helps. x: I hope your problem is resolved sooner than later.
Feb 26, 2013 | Acer Aspire L310 Desktop
No video signal on acer aspire x1200. changed monitors and cables
You should be more specific next time - is it a laptop or a desktop computer, do you have additional graphics card, etc? I've already googled for a PC type. You have a desktop PC which comes with integrated graphics. It has two video ports onboard - VGA and HDMI. Which one did you try? It could also be that you have additional graphics card installed. In this case integrated graphics card is turned off automatically. Sometimes people accidentally connect their display to the wrong port - you should check that. It could also be, that you don't see any video output, because of faulty hardware like RAM, CPU or the Motherboard. Do you hear any beeps or other sounds during startup?
Oct 15, 2012 | Acer Aspire X1200 PC Desktop
Continuous beep beep beep noise.
The Video (Graphics) Card inside the computer is not working. The fact that the monitor displays NO Input Signal shows that the monitor is working. Try connecting another monitor to the computer and you'll get the same NO Input Signal messaged because the monitor is not receiving a signal from the computer as an input source. Also you can try your monitor on another computer just to validate that it is ok.
Jun 02, 2012 | Compaq Presario SR5710Y PC Desktop
No signal display on monitor. Checked another monitor. Purchased a new graphics card, but still have same problem. Cannot install software for new graphics card because of no signal. How can I delete or...
Yes you need to disable the integrated card in DEVICE MANAGER---go to START> right click on MY COMPUTER>PROPERTIES>HARDWARE>DEVICE MANAGER then choose display adapters and double click the device and at the bottomchoose "Disable this device"
Dec 31, 2010 | Acer Aspire M1640 Refurbished Intel...
Necesito saber si tiene doble tarjeta de sonido
No solo tiene una.
Graphics Controller
  • Type Integrated
  • Graphics Processor / Vendor NVIDIA GeForce 7050
Audio Output
  • Type Sound card - Integrated
  • Sound Output Mode 7.1 channel surround
  • Compliant Standards High Definition Audio
  • Speaker(s) 2.0 x Right / left channel
Keyboard
  • Keyboard interface PS/2
Input Device
  • Type Mouse,
    Keyboard
Dec 13, 2010 | Acer Aspire M1641-U1521A PC Desktop
I bought a acer notebook on the 19th oct 2009 it was for a xmas present for my daughter i took it out off its box on 23rd dec 2009.In jan 2010 computer crashed took it back to currys they sent it away to...
1.Try to understand,without waranty not able to service your laptop without charge.
2.I thing you are not statisfing with acer service
3.In this scenario you go to consumer court with strong proof.(that means how many days of your laptop stay in service center only like that)
Nov 16, 2010 | Acer Computers & Internet
The monitor will not get a connection. I need to know where the video card is located.
This is eMachines Support, T6420 desktop computer>Specifications, and downloads page for the User Guides,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6420
The eMachines T6420 does not come with a graphics card from the factory.
It comes with Integrated Graphics.
Integrated Graphics is also known as OnBoard Graphics.
On the motherBoard
The GPU is soldered to the motherboard.
(Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
OR,
someone has installed a graphics card, into the PCI Express x16 slot on the motherboard.
You can determine real easily if your computer is using Integrated Graphics, or a graphics card.
If it is using Integrated Graphics, the monitor will be plugged into the I/O area, on the back of the computer, and into a VGA port,
http://en.wikipedia.org/wiki/VGA_connector
(I/O area;
I/O = Input/Output
The I/O area, is the area that has the rectangular metal shield, and Input/Output devices are plugged into this area.
Devices such as a Keyboard, Mouse, Printer, and so on )
HOWEVER, with the motherboard used in an eMachines T6420, the I/O area could also have a white DVI port.
http://en.wikipedia.org/wiki/Digital_Visual_Interface
This was an option offered. The DVI port still connects to the Integrated Graphics on the motherboard.
The eMachines T6420 uses an MSI MS-7207 motherboard.
(Micro Star International, Inc.)
http://www.tigerdirect.com/applications/searchtools/item-detailsInactive.asp?EdpNo=2665522
The above link is to,
1) Show the motherboard
2) Provides a link to the Motherboard Manual
Looking at the photo of the motherboard, you will see two long White slots.
Above these two slots you will see a longer White slot.
The bottom two white slots are PCI expansion slots.
The top longer slot is a PCI Express x16, expansion slot.
This is where a PCI Express graphics card would go.
I would like you to scroll to the bottom of the page, to the Product Resources heading.
Under it is a link to the Motherboard Manual, for the MSI MS-7207 motherboard.
Also known as K8NGM2-L
Left-click on the blue - MSI K8NGM2 Series Manual.
You will be looking at a blank white page, as the PDF file downloads in the background.
Took 34 seconds with a medium speed DSL connection, for me to download it.
NOW,
No Signal on the monitor, means the monitor is Not receiving a video signal.
1) Check the monitor cable if it is removable. Use it on another working computer to insure it is good.
2) If the monitor cable proves to be good, the next area to check would be the graphics.
If the computer is using Integrated Graphics, and no one has installed a graphics card, the test would be to install a graphics card, and plug the monitor into it.
Computer off, unplugged from power, Anti-Static precautions are observed before reaching inside the computer, and handling the graphics card.
I don't think the problem is the graphics. Could be wrong, but we'll see.
Let's carry the diagnosis past the graphics for now.
I think the problem could be due to a bad Power Supply.
Weak Voltage power rail.
Enough power to light lights, and spin fans (Perhaps), but not enough to turn the Processor on.
(Fans may be spinning, or may just spin a few times, and stop)
1) ALL the lights use Less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Continued in an additional Comment.
Jun 12, 2010 | E-Machines T6420 PC Desktop
Upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
Apr 29, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Acer AOpen AX 6B Plus (91.87810.321) Motherboard Logo
172 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
