Question about Cosco Alpha Omega Convertible 22-150
I need to know how to put my car seat back together. no manaul found for my product model#22233-TSS MFG L#10 b 118430 08/20/2008 can you help me
quare3
  • 48 Answers
SOURCE: can't put back together
Please look at this manual instructions to get a clear help. and dont forget your rating for me. Thanks.
http://www.coscojuvenile.com/instructions.asp
Posted on Jan 25, 2008
  • 7 Answers
SOURCE: putting seat together
http://www.coscojuvenile.com/instructions/ or email consumer@djgusa.com give them your model and manufacture date & they can send you one.
Posted on Oct 15, 2008
  • 25 Answers
SOURCE: i need help putting my
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps. Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat. The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it doesn't twist, either. There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side. Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.) If you also took the **** buckle out, it goes back in from the top. Turn it so that you can slip the metal plate through the slot, slide it through, and then pull the plate flat underneath, so that it can't come back through. One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Posted on Feb 19, 2009
SOURCE: cant put the car seat back together
took the straps off and can't put back together
Posted on Jul 25, 2009
  • 29 Answers
SOURCE: I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
Posted on Mar 20, 2010
Putting a britax car seat back together after washing
You can find free manuals for many different Britax car seats on Manuals Online: http://babycare.manualsonline.com/manuals/mfg/britax/britax_car_seat_product_list.html
Just search for your model (they are listed alphabetically on the site) in the list.
Dec 10, 2012 | Britax Baby Gear
Need manuel for model 5521466A stroller cr seat combination washed it and can't figure out how to get it back together
Go to the Evenflo Site. Hit PRODUCT SUPPORT and scroll to the bottom. In the middle you will see Product Instructions. Click it. Then put in your Model number and Date of Mfg.
The page that opens is a parts order form but in the middle is a $0.00 charge PDF file of both the stroller and Car seat instructions. Try this link if you can. It may take you right to it. Good luck.
Evenflo Product Info LinkOr just go to Evenflo's Site Link that is www.evenflo.com
Jun 18, 2011 | Evenflo Baby Gear
I took the carseat cover off and now i cant put the straps back together. I dont have my manual.Please help with a link to a diagram or online manaul for Maxi-Cosi 22371HFL Car Seat.
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then choose the model carseat you have so that you can download a replacement manual.
If you can't find the product you have, use the "Contact Us" tab to get in touch with the customer service department for your area.
May 27, 2011 | Maxi-Cosi 22371HFL Infant Car Seat
I took carseat apart how do I put it back together?
go on your products website type in make and model and an instruction manual will be available to read or download
Sep 12, 2009 | Eddie Bauer 31447 Booster Car Seat - Sage
I TOOK THE STRAPS OFF TO WASH THE CAR SEAT COVER ON MY GRACO CAR SEAT MODEL 8442CYP AND FORGOT HOW TO PUT THEM BACK TOGETHER
Hello if you have found a solution to your problem please let me know because I have the same problem...thanks
natetheneatfreak@hotmail.com
Jul 10, 2009 | Graco Nautilus 3-in 1 Car Seat
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
Putting Me Back Together???
Unfortunately, all the product manuals I have found do not give instructions for replacing the covers, but give care instructions to spot-clean with a mild soap.
Were there any other parts besides the cover and the 10 screws? Maybe a molded plastic piece that the screws would go into before going into the cover and metal tubes?
My only suggestion would be to search the hem of the cover to find the holes the screws had come from, put the screws through those holes and use them to line the cover up with the holes in the back of the poles.
If you still can't get it back together, it might be helpful to take a trip to a local baby product store (such as Babies R Us) and take a look at the display models. It might help you make heads or tails of that cover. Good luck!
~Alkara
Mar 07, 2008 | Graco DuoGlider LX 7946 Twin Seat Stroller
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Cosco Alpha Omega Convertible 22-150 Logo
83 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
thegtw
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
