Question about Motic DM52 Microscope
Light wont turn on. computer can't see microscope connection. wall charger light is green
Green blinking lights
When you get a Red Light and then a flashing green light (5 green blinks and then a yellow blink) it normally indicates that the battery is dead flat. When this happens you MUST connect your device to the charger that was supplied with the PlayBook (it supplies more power than a standard BB charger) and then the device will automatically power up when ready. If you try and use a USB or standard BlackBerry charger it MAY NOT power up correctly.
wall light
Jun 07, 2012 | Fujitsu AOU18CL Wall Ductless Outdoor Air...
Tip
How to convert a USB Battery Charge Cable to AC
<p>Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless. <br /> <p><br /> <p>Generic Battery <br /> <p>1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy. <br /> <p><br /> <p>2. Connect the USB end of cable to the USB wall charger. <br /> <p><br /> <p>3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light. <br /> <p><br /> <p>iPod Battery <br /> <p>1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod. <br /> <p><br /> <p>2. Mount the USB wall charger sliding the top in half, for the manual. <br /> <p><br /> <p>3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied. <br />
on Aug 09, 2011 | Apple iPod touch
How to charge a psp with usb cable while it's dead
no you should use a computer an dplug it in to it and then an orange light should come on then just leave it there for a few hours untill the light turns green
May 24, 2012 | Sony PlayStation Portable (PSP) Console
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Charger quit and bought one from best buy. The
the point on the motherboard has gone bad and its the problem with the motherboard. find a local technican who can fix this at a cheaper price.
Oct 13, 2009 | Toshiba Satellite A75-S206 Notebook
Dell inspiron 1521 won't turn on!
Try this: remove the battery and unplug the power, hold down the power button for 10 seconds, then plug the power back in, and try turn it on again. If this doesn't work, check the power plugin port, if anything in there is moving around, it might be broken and need to be repaired. Check for a local electronics or computer store for that. The only other problem I can think of is that the motherboard died, probably from over-heating. This usually requires a new laptop, or an equivalent price for a new motherboard. Good luck, I truly hope the first one works.
Mar 30, 2009 | Dell Inspiron 1521 Notebook
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
It wont charge or turn on
Problem not with software, problem is with shuffle. You need to buy the charger that you plug into the wall or car charger. This takes care of the charging problem.
Jan 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Science & Laboratory Logo
43 people viewed this question
Top Motic Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Motic Science and Laboratory Expert? Answer questions, earn points and help others
