Question about Sennheiser EK100G2 Microphone
I am connecting a Sennheiser EK100 G2 wireless receiver into the MIC1 connection on an amplifier to run the audio through a sound system. After doing that and turning the volume up I do get some audio (my voice) but a lot of hiss or static through the speakers. The more I turn up the volume on the master volume knobs, the louder the hiss. What am I missing or doing wrong? thanks
  • 11 Answers
SOURCE: Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Posted on Mar 01, 2009
rockdiarylv
  • 27 Answers
SOURCE: sennheiser e835 wireless mic won't turn on
how long did you hold the on button for? press it longer
Posted on Mar 02, 2009
  • 11 Answers
SOURCE: On/off button fell off Sennheiser wireless mic
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
Posted on Jul 07, 2009
SOURCE: ew100 g2 - getting a lot of distortion and must
Add a DI box to clean up/boost the signal of that mic. If all the channels are doing this, get a bigger (more watts) amp so that you have more headroom.
Posted on Aug 26, 2009
  • 140 Answers
SOURCE: I have 3 sennheiser ew100 G2 handheld mics which
You can send them to Pro Line Music
490 Lincoln Highway
Fairless Hills PA. 19030
215-736-8055
It will cost $65. for evaluation + parts+ aditional time past 1hr. + return shipping.
Posted on Jan 16, 2010
How do i wirelessly connect the reciever to the speaker system/tv?
You'll want to research an adapter for this. Radio shack probably has one of the most inexpensive units available today, but you can find others online, with better quality sound. Start with a google search for what you are trying to do. Google, "how to connect speakers to stereo, wireless".
Keep in mind, not all speakers are created the same. Some have amplifiers in them and some do not. This will change the type of adapter you will need.
Fairly new adapters on the market may transmit audio over a wireless network or even Bluetooth, you will need to research your receiver and/or tv to see if either of these are options for you. Another common thing is a range of branded theatre A/V sound systems with wireless sub woofer and/or back speakers.
Good luck with this, it should be a fun project.
Apr 30, 2014 | Panasonic Se-fx50 Digital Receiver
How should I connect an ATM73a headset to a sennheiser SK300
Audio Technica and Sennheiser each have proprietary connectors for their mics. A lot of times the mics require Phantom power which is drawn from the battery of the pack.This is important as the mic will need to be wired correctly to function.
The first thing you will need is the correct plug from the company. Check with Sennheiser customer Support for the correct part. If you aren't extremely good at soldering, do not attempt this. You can change the plug but the wires are extremely delicate and can short easily. Moreover because of the phantom power, the plug must be wired correctly for the mic to function, or you may end up damaging the mic by sending phantom power up the wrong line. I would advise having a music store or pro audio service that handles these products do the wiring for you. If you feel you are up to it, you can do it yourself, but be careful.
Feb 19, 2011 | Sennheiser SK 300 G2 Wireless Bodypack...
Ew100 receiver is getting siganl but no sound is coming through
Maybe the gain in the receiver is down.
You can adjust the outputgain the menu.
Good luck,
Gerard
Nov 06, 2009 | Sennheiser 100/500 G2 Series Wireless...
We have a Sennheiserew100 G2 mic kit with a wireless lav mic and transmitter we use for a canon xh-a1. The shotgun mic has been prefect but the lav mic is creating a static/noise in the background but then...
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Apr 13, 2009 | Sennheiser 100/500 G2 Series Wireless...
Frequency clash
There are different frequencies available and being used in each location.
To get a basic idea of which frequencies are available in your area, try this online tool:
http://www.sennheiserusa.com/findfrequency/
or use the literature provided with the Sennheiser gear (usually a useful chart comes with the wireless gear).
Also, remember that your transmitting frequencies need to be spaced apart a minimum of .400 MHz (or 400 kHz).
Frequency selection shouldn't cause feedback problems though. If you select a frequency for a mic that a local TV station is already using to broadcast, it will cause RF Interference (Radio Frequency). You'll probably hear static noises, pops, or since your Sennheiser has a Squelch feature, just drop-outs in audio.
So first consult the available charts to find a set of frequencies that should be available in your area. Then, if one of your mics is experiencing such an issue, try moving it .400 MHz to the nearest unused frequency and see if the RFI goes away. Repeat until the RFI no longer manifests.
Jan 30, 2009 | Sennheiser 100/500 G2 Series Wireless...
How do you connect wireless headphones to back of receiver?
use the front pre-outs located immediately over the red "right" A&B speaker connectors in the rear of this unit. connect with a high quality stereo  gold plated rca cable.
Jan 08, 2009 | Yamaha RX-V659 Receiver
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
Sennheiser EK100G2 Microphone Logo
107 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
