Question about Samsung CXD1342 13 in. Combo
Need codes for samsung tv/vcr model number cxd1342 for rca704 universal remote
5 Suggested Answers
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
  • 17 Answers
SOURCE: need samsung universal remote code
20739. 20045, 21014
try these- depending on the remote you have
Posted on Jan 11, 2010
SOURCE: need samsung CxJ1952 universal remote code
Can anyone pls help me with the universal code of Samsung CXJ1952.
Posted on Sep 26, 2010
gopakumarg43
  • 75452 Answers
SOURCE: I need a code for our Samsung TV/VCR using a
Hello
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR.
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
0358_0942
Posted on Nov 22, 2010
I have a TV/VCR Samsung model CKJ1352 I need the code for my Philips Uinversal Remote Model PS- 435S
None of the combo units will program with a universal remote--codes are changed from model to model and year by year.
Dec 03, 2012 | Samsung CXJ1352 13 in. TV/VCR Combo
I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
I hope this helps.
Oct 03, 2011 | One For All URC-3021 Remote Control
I have a Samsung LCD TV and I would like the code needed to programme my Sky remote The model no is Le26b450 c4W Can you help please
Universal remote codes are determined by the maker of the universal remote, not the maker of the tv, unless they are both made by the same company. Determine the maker of the universal remote and it's model number, then go to the universal remote makers website and look for codes under the name of the tv (or dvd, vcr, etc) that you want to program the universal remote to operate. Programming instructions should be on the universal remote makers site as well. I hope this helps. BobYa
Mar 09, 2011 | Televison & Video
Need the remote code to my Samsung TV. My model is: TVN5054CA
Hello
Three digit universal remote code for Samsung Tv are:
002 012 102 103 112 212 502 512 818 914
Four digit remote code for Samsung TV/VCR/DVD combo is
0942
DVD/VCR cobo are:-
0455 0963
TV/DVD combo is
0942
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 28, 2010 | Samsung CXD1342 13 in. Combo
I am trying to program my RCA Universal Remote (Model #RCR312WR) for an old Panasonic TV (Model #PVC2060) with built in VCR. I need to find the TV and VCR code for it. Thank you.
Try 003, 054, 055, 062, 070, 148, 149, 170 or 171. They seem to be consistent numbers for the Panasonic TV's.
You might have to enter a different code for the VCR.
Try 246, 285, 334, 340, 350, 363, 373 or 374.
I couldn't find any codes in my library for a TV/VCR combination so the remote might have to be coded separately for each component.
Hope this helps
Oct 28, 2010 | RCA Universal Remote Control
How do i program my insignia NS POP42 plasma tv and my samsung dvd recorder and vcr dvd VR320 using my phillips universal remote
Instructions for programming your universal remote should be included in package with the device. Codes for many remotes can be found at InsigniaProducts.com. Just search for your model number, NS-PDP42.
Jan 19, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
Device code for universal remotec remote
I need the model number of the remote to help you.
Thanks,
Jim
Apr 15, 2009 | Universal Remote Control 6-Device...
Samsung CXD1342 13 in. Combo Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
