Question about Jet 3 Ultra Power Chair
Hello. I have a jet3 ultra. Just installed new batteries and they are fully charged. When I push the joy stick in any direction I hear a click coming from the motors o release the stick and it clicks again. I have no movement or error codes. I do have the motors engaged. Can you suggest a fix for my issue?
  • 9 more comments
  • askgary Oct 09, 2010
    i have tried the speed at all settings. Just makes a click noise. Doesn't move
    The speeds are set properly the fuses are ok. Who can help me?
    the control module wS replaced 6 weeks ago. I don't believe this is the issue.
    This was a working chair. The batteries would no longer hold a full charge so they were replaced. Now, with new, fully charged batteries, I get a click in the motors when they are engaged in any direction. Do you still think I have a faulty controller?
  • askgary Oct 10, 2010
    So far no one here is an expert. You're only applying possible common sense answers to my problem. I would consider someone who has actually owned or actually worked on this device to be an expert. You're all just guessing. I could pay my neighbor to guess. Who here is steal expert with a Jet3 Ultra scooter?
    So far no one here is an expert. You're only applying possible common sense answers to my problem. I would consider someone who has actually owned or actually worked on this device to be an expert. You're all just guessing. I could pay my neighbor to guess. Who here is a real pexpert with a Jet3 Ultra scooter?
    So far no one here is an expert. You're only applying possible common sense answers to my problem. I would consider someone who has actually owned or actually worked on this device to be an expert. You're all just guessing. I could pay my neighbor to guess. Who here is a real expert with a Jet3 Ultra scooter?
  • askgary Oct 11, 2010
    Still looking for an expert on the UltraJet 3 Scooter. Not looking for someone to recite solutions from the manual or common sense solutions. I have the manual, I have common sense. I need an EXPERT.
    Really, thanks to everyone for all the suggestions. Still looking for an EXPERT!
    OK... I have tried everything in the manual.
    I have the manual.
    Batteries are new, correct and charged.
    All the wiring is properly connected.
    Both of the motors are engaged.
    The control module has been replaced recently.
    All 4 of the motor brushed have been checked.
    There are no error codes.
    The charger is working.
    The chair is not locked.
    The chair is on level ground.
    The fuse is OK.
    The batteries are connected properly.
    There are no frayed cables or shorts.
    I am sitting in the chair when I am testing it.
    I have tested it with out sitting in the chair.
    I weigh much less the the max weight.
    The motors, both of them, click when the joystick is moved in any direction. Then they click again when the joystick is released. Nothing moves.
  • askgary Oct 18, 2010
    I know about this connection ant it is firmly in place. When the charger is plugged in I get no respond at all. This is how it should be. When it is unplugged I get the clicks. This is still an ongoing issue.
  • 3,247 Answers
Sorry to hear you are having problems with your Jet3 Ultra chair.
I will not claim to be an expert and add to your annoyance.
However, as an engineer I can see that there is some sort of an interlock that is in place which is preventing the chair from motion. You have listed everything that you have checked and I admire you for your patience and diligence.
One thing I am aware is that these chairs disable the motor movement when the wall charger is connected. Obviously this is a safety interlock. I am getting the impression that perhaps during replacement of the control and batteries, a wire has been knocked off that comes from the charger connector to the control. This wire tells the control that the charging is in place. Are you able to trace back from the charger connector to the control to see if a wire is missing?
This could be the problem. The chair might be thinking that it is still being charged and does not move even when the joystick engages.
I don't have access to any wiring diagram details to really help you on this.
Posted on Oct 11, 2010
  • 2,973 Answers
The description of the problem could mean that the carbon brushes on the motor need cleaning. They are not making proper contact with the rotor and hence despite to clicks the motor is not getting the required current. There carbon brushes are just below the main wires where they connect up with the motor.
  • Rinoo Kumari Oct 11, 2010
    On second thought, just tap lightly on the wire end of the motor and then see if the motor works. This tapping sometimes removes the carbon dust and thus the carbons make contact with the rotor.
    Genius:
  • 1,035 Answers
Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors.
Posted on Oct 10, 2010
    President:
  • 2,777 Answers
Yikes, this is a control module problem on the device, I have seen it before. Hopefully you still have the old batteries and can return these new ones, if that was the reason you replaced them that is. You are going to need to get the chair serviced. Let me know if you need the contact information for someone to fix it.
Thanks
Tim
Posted on Oct 09, 2010
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Wow, ok well it's possible you got a fault module. Was it replaced by a shop? If so they should do the work for you for free to get it back running...
    Thanks
    Tim
  • Tim Grayson
    The chair was working fine before you replaced the batteries? Hmm let me check further into this, but it's really the only thing that makes sense. Give me a bit to verify here.
    Tim
    President:
  • 1,033 Answers
Have you got the speed dial set to move, both my parents have these and they have a habit of turning them on but not increasing the speed at the joy stick.
I have a jazzy Select GT power scooter, on the charger I have a red light and green, I put it on charge and have both green lights on now but the controls near the joy stick and on and off light nothi
need more info on equipment to answer ,scooters dont have joystics powerchairs use joysticks if you have a powerchair that has not been charged for over two weeks the batteries have probably died
in this state the charger will not go into charge mode only the power light and poss the fully charge lights will light
as a quick test a 24 volt bulb from a scooter or lorry with 2 wires attached pushed into the two outer holes in the joystick charge socket should light up if it wont batteries are totally dead
Nov 21, 2014 | Health & Beauty
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
My power chair runs but wont move.
re-engage the motors look for two levers one on each motor and move them to locked position
Oct 21, 2012 | Golden Technologies Alante' Power Chair
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
Directions to replace the battery in a jet3 power
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Aug 02, 2010 | Jet 3 Ultra Power Chair
The battery,s go dead over night when i am not
ron, if your batteries have ever gone dead or amps has gotten below norm, then the batteries will never hold a charge again. replace batteries.
Feb 22, 2010 | Jet 3 Ultra Power Chair
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
I just bought a jet3 ultra and it looks new, but battery is dead. How long should I let it charge up? I have the power cord. Do you have it sit in it to make it go? How do I get it to go?
If the battery is dead I would have the batteries load tested. Let it charge 12-14 hours. To operate the chair push the power button and push the joystick in the direction that you want to go.
Dec 16, 2009 | Jet 3 Ultra Power Chair
I have a quatum 610 power chair when i use it the batterys (new) discharge fast i get about 2 miles per charge it makes a clicking noise but not all the time and even makes the clicking noise after its...
It is not shutting off. You need to bring it to an expert for service. Your problem sounds like it is electronic, not mechanical.
To stop it from discharging you can disconnect the batteries. The batteries should be hooked up in series 24vdc not parallel 12vdc.
May 16, 2009 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
