Application 'Nuendo 3.x' has caused the following error: There is an USB communication problem. Please connect the protection device to another USB Port.
  • 10 Answers
SOURCE: Hi, I'm having problems port forwarding
- Please check if it's UDP or TCP. You might have selected TCP for port forwarding but Torrent also uses UDP. For some ports that's important to make both forwarding. One for TCP, the other for UDP.
- If this doesn't work, you need to go deeper. You need to have access to an external computer on internet (a friend) from which you can start a telnet. For instance :
telnet mypublicip 45682
On your side, you need to check what's coming on your network interface. Two options to achieve this :
- Either you book a linux live cd (kubuntu), and you run in a console :
sudo tcpdump -ni eth0
(eth0 is the first ethernet adapter of your workstation).
- Either you use wireshark on Windows, this should do the trick, but you cannot be sure that there is no other software blocking on your current installation.
Regards,
Posted on Jul 10, 2011
SOURCE: Installed but will not Record.
Thanks, I am recording as I type this. I had to re install and go to www.Ion-audio.com and download the driver ( the top one) then I went to the control panel then to systems/hardware/device manager/ then click on VCR2Pc and chose update driver then it allowed me to go thru the install wizard process. thanks for all your help!
Posted on Jan 18, 2009
MUKHTAR
  • 2017 Answers
SOURCE: I get the following when trying to scan
reinstall the driver again and chage the usb cable and put in other usb port.
Posted on Sep 08, 2009
SOURCE: Garmin eTrex Legend using serial connection to PC.
Re-installed the USB-to-serial driver, the DNRGarmin software, and the Garmin Communicator to resolve the problem.
Posted on Jan 03, 2010
  • 644 Answers
SOURCE: I have installed the driver
Ensure the cables are all securly positioned, Check that you have all icons pressent, if you only have 2 then it didnt install properly, if you have all 3 icons goto my computer right click, click properties and find device manager, click the (+) next to the universal serial bus controllers, right click the usb composite device entry and then click remove, disconnect the printer from the computer and then reconnect, the found new hardware should appear, click next through all of the pages and then click finish, if the problem persists try a different usb port.
Posted on Aug 12, 2010
PLEASE help unlock my device E5331s-2 IMEI::860667017553111
Hi. You can unlock your Huawei E5331S-2 safer and easier using unlock code. You can get the unlock code for a Huawei E5331S-2 from SimpleUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
If your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Jul 14, 2014 | Huawei Unlocked E5331 Wireless Hspa 21m...
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
7280 507 error
Cause 1 If this error occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
You need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer. Before you use Application Loader to install software on your BlackBerry wireless device, verify that the necessary device software is installed on your personal computer.
    To verify what device software is installed on your computer
    1. In Desktop Manager, click Help>About Desktop Manager.
    2. Click the Device Software tab.
    The Device Software tab lists the device system software installed on your computer. If the tab is blank, then no device software exists.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
OR
Cause 2 It may occur when all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software. Cause 3 It may occurs when the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
It may occurs when the BlackBerry smartphone is connected to a laptop computer using a docking station. You need to complete the following steps:
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
Nov 08, 2009 | RIM BlackBerry 7290
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
Blackberry 8100
error 507 means that the operating system on the handheld is missing.
1) Download the latest version of the handheld os from your carrier's web site
2) Execute the downloaded file
3) Locate and delete VENDOR.XML from your PC's C: drive
4) Connect the BB and start Desktop Manager
It should reload now.
Jun 25, 2009 | RIM BlackBerry Pearl 8100
Phone has error code 507 with a square and a triangle, and a line running trough it
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
Cause 4
Resolution 4
Re-install the BlackBerry Device Software using the Application Loader tool.
May 17, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
507 error resolution
The error message indicates that no applications are loaded on the BlackBerry smartphone.
Cause 1
While using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
Cause 2
Even after performing these steps if you could find the same error, please let us know so that we can provide the further resolution.
Mar 07, 2009 | RIM BlackBerry 7290 Smartphone
Reload software 507
Cause:
Resolution
Cause 1
Resolution 1
Cause 2
Resolution 2
Cause 3
Resolution 3
Cause 4
Resolution 4
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
Desk top APC UPS ES750 not communicating
Here is an answer I got from APC when one of my client got the same problem as you did:
The error message would pop up if the link between the computer and the UPS is weak. I cannot rule out a problem with the cable or the UPS. In order to confirm the same please try the following steps which might help :
1) Ensure that the USB cable is properly connected to the USB port of the computer.
2) If the PC was powered on before the UPS, communication will not be achieved until you disconnect and reconnect the USB cable to the host. In this case, you need to disconnect and reconnect the USB cable to establish communication.
3) Some other software is polling your USB port for another device, thus causing the UPS software to temporarily lose communication with your UPS. If this is the case, you would need to shut down that application.
4) If you have any other USB devices connected to the PC, disconnect them and then try plugging in the cable.
If the issue persists, please visit the following link which lists few troubleshooting steps :
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=oXhRFGEh&p_lva=&p_faqid=2923
Dec 13, 2007 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
Computers & Internet Logo
1,093 people viewed this question
David Payne
David Payne
