Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Prints very small on the paper - HP PhotoSmart C4480 All-in-One Printer InkJet
    Brigadier General:
  • 4,044 Answers
Check your magnification or Reduction settings and your paper selection settings on the printer itself. These are normally available through the printer properties page of your printer.
Posted on Oct 09, 2010
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
My canon ir2016 copier comes with blank paper when printing and the paper jamed before it reaches the paper pick up roller
Check very carefully it sounds like something small is caught in the paper path, probably a small piece of paper.
Dec 11, 2014 | Canon Office Equipment & Supplies
Why does the printer use one black cartridge and not the other? Is there some way of instructing it to use the left hand one too?
the pixma printers use the large black tank in most modes like text and standard (default) or fast photo printing .. thats most economical when you are using just plain paper .... it will switch to the small black tank only if you select "High" quality mode .. that black matches the nature of the color inks much better and results in really good color pictures if you are using Gloss or Matt high quality photo paper .. you can select the quality level by the following ... when you start to print, a window comes up where you can select which printer you want ... at the right of this window is "preferences" .. click that .. now select the type of paper and "High" quality mode .... now the printer will slow down but will provide really nice results and it will use the small tank black ink instead of the large tank ....the small tank is only used for "high" quality photo prints which is only needed for high quality photo paper .. if you havent tried that yet you might want to get some glossy photo paper (either Canons or Costco has great stuff if you want a lot, like 150 sheets) but most glossy paper will work except colors might need tweeking for some ... print a nice photo in the high quality mode and you should be really impressed .. and you will be using your small black ink tank .. you might want to make the first few pictures small (2x3 inch) untill you are sure everything is the way you want it .. i usually print in the top left corner first .. then reinsert the same paper and try again right next to that .. i do that until i get the colors perfect .. then i print big .. 5x7 or even 8x10 on a new sheet... the high quality mode can be selected for just plain paper and it will use the special black ink but it doesnt result in a better picture .. so no point in doing that unless you want to experiment .. if you never print high quality photos then you will never use the small tank black ink .. it will still be used up eventually because of normal head cleaning the machine does automatically .. ...
grey scaling does not select the special ink unless you select "High" for the quality setting .. then yes you can print using that small tank black ..again it will buy you a lot if you are using High quality photo paper ... almost nothing for plain paper but at least it will allow you to use that ink .. ..
Dec 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printed text is very small, not legible and does
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Dec 08, 2009 | HP DeskJet 930c InkJet Printer
Paper is getting stucked in the canon printer
Just clean the print head and also ensure that the paper is placed proprely and no other piece of the paper is inside it . Most probably cleaning the print head willsove yur problem
Thank U
Please rate my solution as it wil cost u just one click
Nov 05, 2009 | Electronics - Others
HP 6540 Lights flashing can't print
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
Paper light blinks so nothing will print. There is paper
look for a small switch or, a small red light (infared sensor) in the paper well (where the paper enters) repair the switch or, clean the lens of the sensor
Sep 09, 2009 | Brother Office Equipment & Supplies
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
When I tryto print 5x7 prints from windows fax viewer my photosmart all in one model C4480 is printing the first 5x7 fine but the second 5x7 also has a small wallet size printed ontop of it
Solution one: Print on heavier paper Try printing on a thicker type of paper. Solution two: Check driver settings If printing on plain paper, make sure the driver settings are set to Plain Paper.
  1. To change the driver settings, click the Properties button in the Print window.
  2. If the Paper Type is not set to Plain paper, click the drop down box and choose More .
  3. Find and click Plain paper , then click OK .
  4. Click OK to return to the Print window and click OK to continue printing.
Jun 18, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
23 people viewed this question
Seeker5211
Seeker5211
